Thread: XX1 Chainrings
    Apr 2013
    XX1 Chainrings
    Probably many posts about gearing on the xx1 around, but I am looking for some actual experience. I'm thinking about switching out my 32t front chainring for a 34t or possibly 36t. Anyone have experience with riding a 32t and then going up to a 34 or 36? How much of a change is it going up a few teeth in the front?
    I'm also a little worried about chain length. My current chain is cut to fit a 32 and I used SRAMs instructions on fitting chain length. Will my chain fit the larger chainrings?
    I do enjoy a lot of climbing on the bike, but with a light hardtail I rarely used the 42 rear with the 32 up front in my area. I can see on a longer ride wanting to have the 42 to fall back on, but I've set my bike up more for racing in mind. I'm thinking 1 hour -2.5 hour rides tops, so I'm not too worried about suffering up a few steep climbs if need be. Any advice would be greatly appreciated.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    It sounds like you could push a larger gear.
    Not all bikes will take a bigger front ring than 32 with the XX1 chain line, So it would pay to check
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Apr 2013
    Thanks for the info muzzanic, that's a good call on the front ring sizing. I will have to double check to make sure anything bigger will fit my bike. I do remember the front ring looking like a tight fit when I was installing.
    I am running a 38T up front with a 156Q no problems with clearance. I switched directly from a 28/36 to my 38/42, it was tough but got over it in about 2 weeks.
  1. Why 10-speed chainrings sell at much higher than 9-speed chainrings
    By solitone in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2014, 05:49 PM
  2. Replies: 1
    Last Post: 10-08-2012, 01:26 PM
  3. New chainrings..?
    By thomllama in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-18-2012, 12:01 PM
  4. need new chainrings
    By mission2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-13-2012, 09:13 AM
  5. XX Chainrings
    By pcire in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-08-2011, 05:49 PM
