• 02-09-2013
    mazafakka
    XX1 Cassette Creak (thought it was bottom bracket)
    A word of warning to anyone experiencing a creaking sound with their XX1 setup:
    I had what I thought was a creaky bottom bracket on my SC Highball C. Whenever I was putting any kind of torque into the highest two gears (smallest 2 rings) on my XX1 I heard a creak. After disassembling, cleaning, re-greasing, and reinstalling the BB, the creak was still there. I then removed my XX1 cassette, which was still properly torqued, cleaned and regreased the threads and every surface where the DT350 cassette body and the cassette touched. This solved the problem. This is actually the second time I've had to do this since installation: I installed the XX1 kit on 12/30/2012, and I've ridden 330 miles on the bike since. Hopefully this doesn't continue, because it'll be annoying to have to remove and regrease the cassette every three weeks or 165 miles...
    I am posting this to hopefully save some other folks from spending 1-2 hours pulling the cranks and BB off their bikes.
  • 02-10-2013
    limba
    Hmmm, anyone else have this problem?
  • 02-17-2013
    cityloopcycles
    I experienced this last night on my ride home. Same two gears under torque. I haven't removed and reinstalled the cassette but it sounds like that will fix the issue. Ill let you know.
  • 02-21-2013
    lokisare
    I experienced this with a SRAM 1080 (10 speed XO) cassette, brand new only had about 7 hours of riding on it. Turns out it's because the individual chain rings are attached to the next by little pins, and instead of the whole cassette/each chainring having grooves interlocking into the free hub there's just a small section which does. This means that in certain chain rings, the force is not transmitted directly to the freehub but rather transmitted via these pins to the next chain ring (or across several) to the one or two which have interlocking grooves into the freehub body.
    The creaking was only in the chainrings that didn't interlock with the freehub body, the creaking was caused by the force being transmitted across these pins.
    Not sure on the XX1 construction but it may be a similar issue?
    Being 10 speed the solution is to change cassettes to one which has each chainring grooved to mesh with the freehub body (ie. shimano). Not sure what XX1 options are.
  • 02-22-2013
    chrisgardner73
    Not sure if you're still having this issue, but...
    Did you straighten the derailleur hanger? I ask because I had the creak too, and asked a friend at my LBS about it. He immediately pulled out the straightener, and now the creaking is gone. Shifting is even smoother as well now. You might want to try this, if you haven't already.
  • 02-26-2013
    cityloopcycles
    So I removed my cassette, cleaned, lubed, and reinstalled and it still creaks. Its very odd that I can only get it to creak in the 12 and 10 tooth cogs. I'll check my hanger alignment tomorrow.
  • 02-27-2013
    tavaenga
    I also experienced a creaking sound with my XX1 when either pedalling under load or even sitting on the bike and setting sag, which I initially thought was caused by the BB or suspension pivots on my Blur TRc. Took it to my LBS and the mechanic removed the chain and then demonstrated the creaking had stopped. He said the likely culprit was a faulty clutch in the Type 2 mechanism. I then took it direct to another shop who are directly connected to the SRAM distributor here in Hong Kong and the derailleur was immediately replaced under warranty - creaking disappeared. They said it was a "known issue" without elaborating. Not a great start with XX1 but a fantastic product and great service too...
  • 02-27-2013
    limba
    Not what I wanted to hear. I don't care if a company fixes things for free, they shouldn't break in the first place.
  • 02-28-2013
    millertm
    From what I have heard the XX1 cog is a one piece unit C/C'ed. I do not believe that there are any pins holding the sprockets together. I could be wrong but I remember looking at the vid they had out about this new 1X11 setup.
    Mark
  • 02-28-2013
    cityloopcycles
    so my hanger was straight. i'm not sure what else to really check but i'm also not really worried about it. i've only been able to make it do it during my commute on paved roads in the 2 hardest gears. i may remove the cassette one more time just to triple check it but otherwise no big deal.
  • 03-01-2013
    chrisgardner73
    Sorry to hear that. Aside from the straightening the hanger and removing/re-installing the cassette, derailleur, and wheel, I can really think of anything. Could the XD Driver have anything to do with it? Just a thought, but maybe you could remove and re-grease that?
  • 03-01-2013
    limba
    Cityloop, did you read this?
  • 03-01-2013
    cityloopcycles
    Limba,
    Yeah I saw that but my bike only makes that noise under harder efforts. It's a brand new epic s-works and doesn't make a peep otherwise. it's a very quiet bike. I'm going to try a few more things. I'll keep you guys updated. Thanks for the suggestions.
  • 05-09-2013
    s-works-addict
    I have this exact problem! It was hard to trace but the same issue of creaking under load. SRAM replaced my 1 month old derailleur under warranty but now on my 4th ride on my new one it's creaking like an old pirate ship. Here's a video of me getting it to make noise.
    SRAM XX1 Noise Problem - YouTube
  • 05-10-2013
    flipnidaho
    Originally Posted by s-works-addict View Post
    I have this exact problem! It was hard to trace but the same issue of creaking under load. SRAM warrantied my 1 month old derailleur but not my on my 4 ride on my new one it's doing the thing again. Here's a video of me getting it to make noise.
    Mine does the same thing. To fix it, I did two things:
    1. Take the derailleur off the hanger (T25), and grease the threads and the surface of the hanger where it interfaces with the derailleur. My theory is with the friction clutch, it transfers a lot of the flex to the derailleur body and hanger area so this has to be cleaned, greased and tight (you can actually see the flex on the body as the clutch is engaging).
    2. Take the cap off the clutch. There is a T55 torx bolt beneath the cap that controls how much friction is applied. Turn it counterclockwise until the noise quiets down. Replace cap.
    Some folks have completely torn down the derailleur to clean and re-grease the clutch area as well...
  • 05-11-2013
    goodoljake
    I have two and one does the exact same thing as in the video posted. i have tried to pop that little cap off with my fingernail with no success. how do you remove it?
  • 05-11-2013
    s-works-addict
    I think the best thing to do is arrange for a warranty exchange with SRAM through your LBS. They've done blind-exchanges for me as long as you give your LBS the serial #. Helps prevent downtime!
  • 05-11-2013
    goodoljake
    I'd love to, but I got it off ebay.
  • 05-11-2013
    s-works-addict
    If you try to adjust it yourself - post some pics or video please!
  • 05-11-2013
    flipnidaho
    I used a very tiny screwdriver (the type of screwdriver you use for eyeglass repair). However, a small pick would work just as well. The cap is not a critical part. It just covers the T55 so if you scratch it up a little bit, it's no big deal.
  • 05-11-2013
    goodoljake
    so the entire nickel size cap or the smaller center part comes off?
  • 05-11-2013
    flipnidaho
    Just the center cap. It should spin when you turn it. It should just pry off but you need to get something beneath it. Even a safety pin should work.
  • 05-12-2013
    goodoljake
    right on, not sure if anyone has seen this thread, but I will probably try to lube the outer parts as these dudes are talking about. http://forums.mtbr.com/sram/xx1-knoc...-836175-2.html
  • 05-13-2013
    goodoljake
    Ok so I removed it, cleaned the hanger and greased the hanger. cleaned off the der. and backed off the tension screw deal. seems to have fixed it, at least on the work stand and in front of my house. time will tell. if it doesn't then i will definitely tear that thing apart and see what happens. good luck to you all and hopefully i won't be back.
  • 06-02-2013
    jwbender
    Hey guys, my center cap is adhered w loctite and more secure than fort knock (haha). Any ideas on how to pull it off? Some guys are saying their plastic cap rotates, my has excessive loctite and simply will not come off.
    I have isolated my noise the XX1 rear D and will do almost anything to fix this now. Any ideas that you have would be really helpful.
  • 06-02-2013
    dlennard
    The center cap on the clutch is just a little plastic cap which is a little hard to get out. Just use a dental pick or really small screw driver to pry it out. The loctite you see is on the clutch bolt which I think is a T55.
  • 06-02-2013
    jwbender
    Any chance you could attach a photo w the little plastic cap picked off the rear d? I want to be sure I am digging at the correct cap. I cannot seem to get the cap off--although I can see the loctite, I cannot get that piece to budge.
  • 06-03-2013
    dlennard
    Here you go.
  • 06-05-2013
    custmpaint16
    This thread has been very helpful!!! I've had a nasty XX1 creaking, and trying to get rid of it has almost put me in the loony bin!!! I tore down the derailleur, greased every part in there, including all of the clutch parts (of which, the actual clutch/bearing inside was dry and rusted from the manufacturer), changed my bottom bracket (slathered in pipe joint compound), greased my pedals, retensioned my spokes, rebuilt my hub, greased all of the suspension pivots and bearings...until finally...
    What solved it:
    -Removed cassette, greased the "HD" part of it. I got the grease in where the actual insert makes contact with the sprocket housing. The piece that spins when the cassette is removed, grease all that sh*t in there where it touches the rest of the cassette...QUIET WILL FOLLOW, it'll keep you from ending up on the street corner talking to yourself!
    Hope this thread helps others as much as it did me...good luck.
  • 06-05-2013
    seano
    My bike creaks like an old p-o-s. I think its the derailleur as lots of lube quiets it for a while... Usually every 3-4 hours of continuous use it sounds awful. I can usually deal with the noise for a while, but then I've begun to wonder if that derailleur is adding friction to the whole system? Mine is pretty quiet until under heavy load -
    I've gone the lube route mainly because this rears its ugly head many, many times throughout endurance races I've been doing. I think its probably time to look at that tension screw and / or have the shop talk to SRAM
  • 09-12-2013
    LowLow
    Seano - what did you end up doing? Mine started creaking and I've greased the freehub and the derailleur bolt and confirmed that my hanger was straight. I haven't played around with the clutch yet. I wish expensive new parts would just work without any problems!
  • 09-12-2013
    seano
    Yeah... bugged me, too - so the shop warrantied it with SRAM. It helped that the shop mechanic is my 24 hour mechanic and was able to speak rather eloquently about how awful the thing was creaking (I hand him my bike every lap... roughly every hour... so it would go from whisper quiet to rattle trap creaky in 1 hour. During the race he'd spin the thing upside down and sideways in the stand and bathe it in lube). I think the new derailleur solved the prob... now its so quiet I hear the BB clicking :) Ah well, they look pretty, eh??
  • 09-27-2013
    Rey Recinto
    I then took it direct to another shop who are directly connected to the SRAM distributor here in Hong Kong and the derailleur was immediately replaced under warranty - creaking disappeared. They said it was a "known issue" without elaborating. Not a great start with XX1 but a fantastic product and great service too...[/QUOTE]
    bro. tavaenga,
    Are you from Hong Kong? Which shop are you referring to? the one who is connected with the SRAM distributor in HKG? Can I know the name of the shop?
    I am from NOrth Point...thanks
  • 09-28-2013
    azpoolguy
    Mine just started creaking after 1,000 miles. I traced it down to the B-bolt and small plate that the B tension screw rides on. The new Sram service manual shows replacement of the B-bolt and retaining washers now.
  • 10-06-2013
    threepin
    just had the same issue with the same solution as the OP , unfortunately finding this thread after pulling cranks bb etc.
    OP did this issue keep coming back?
  • 10-06-2013
    mazafakka
    It's interesting that you guys are solving the problem by dealing with the rear der instead of the cassette. Maybe I will try that too. But as an update, I still have this problem; I'm required to remove my cassette and re-grease the interface between the freehub body and the cassette every few months. More often if I get rained on during a ride...
    Hopefully you guys have better luck than I do!
  • 10-06-2013
    threepin
    i did not end up pulling the d apart as the noise did not sound anything like the clunk i was hearing on vids and because its on a hard tail so there is little to no rear d movement while pedaling under load
    interesting that i got rained on prior to the issue coming up
  • 10-27-2013
    jimithng23
    What solved it:
    I did this.
    After removing the cassette, I rotated the cassette carrier with my fingers and there was a nasty squeak - deduced this had to be the culprit.
    Smashed a liberal amount of grease in there like custmpaint did.
    Boom. Creak gone.
  • 12-24-2013
    PhilGau
    Same problem here. I suspected the BB and managed to track it down to the cassette. I just liberally greased the outside of the entire freehub and it seems to have fixed the issue.
    Funny thing with creaks. We always suspect the BB but it is hardly ever the cause.
  • 01-03-2014
    BPSarge
    Developed a creak as well and I was thinking it was the BB so I started with the cassette like Mazafakka did.
    First thing I found that the cassette was loose compared my previous XX1 set up on my TRC, second it has very light amount of grease on the hub threads.
    So I cleaned off the hub and the cassette and installed a good amount of grease and tighten the cassette "snug' and now the noise is gone :)
    MTBR threads to the rescue:)
  • 01-20-2014
    seano
    Hah! Like Mazafakka and others had previously mentioned... it was surprising that some of us solved it fixing the rear derailleur. That was then, this is now: the original creaking I had was nothing compared to this weekend's creak... it's time to remove the cassette and lightly grease everything (this creak is definitely different, too).
  • 04-05-2014
    daave77
    Thank you to all posters, I have just forked out on the X01 groupset to find out (now after I've almost been admitted to the asylum) that it shares the same frickin creaking under load in the smallest two cogs!
    Suffice to say (being an Internet purchase) I will be packing grease everywhere tomorrow in a bid to silence the noise and maintain my mental health in a normal-ish state!
  • 04-14-2014
    Kegelhoff
    My creaking just started this past week after a good 6 months and lots of riding. Like most others I have spent quite a bit of time tracking it down. Changed the rear wheel thinking it was the hub but the new wheel had the same creak going about 30 minutes into the ride. I always grease the threads pretty good before installing the cassette. As the creak got louder on my last ride I stopped riding and actually grabbed the cassette on both sides and rocked it back and forth. Make the EXACT same creaking sound! So, mine must be in the cassette to hub mating and not the rear derailleur ??
    Wondering if anyone else who has the creak tried rocking the rear cassette to see if you hear the same creaking sound?
  • 04-14-2014
    daave77
    I solved mine almost completely by putting a liberal amount of lith moly greased on hub and inside cassette so we'll see how long that lasts!
    I spoke to the head technical guy at Sram UK yesterday, by pure fluke one of the race organisers at my XC race knew him and sent me to him. I can confirm Sram DO NOT know about the creaking cassette problem, they may replace items for people but until yesterday the tech guys knew nothing of the problem so they have at least been told now!
  • 04-14-2014
    daave77
    Oh and the little plastic cap on on the clutch part of the XO1 rear mech doesn't come off with a pick, small or large screwdriver! It looks a little different to the xx1 rear mech but the metal around it will give and shard before you can get the cap off! Suffice to say I left this as it was!
  • 05-05-2014
    AllMountaineer
  • 02-10-2015
    engrmariano
    the studs are the culprit!
    i've experienced this problem when i'm mashing uphill, regardless of what gear i am.
    i've replaced bearing of my linkage (although they are due for replacement), issue not solved. replaced BB to CK (also due for replacement), issue still not solved!!!
    so i asked a fellow rider to ride with me uphill and catch where the sound is coming from, both of them noticed it's coming from the back. so after the ride, i removed the cassette & greased the freehub & put some oil in the studs (purple arrow) that's holding the 42T & the rest of the cogs. and wha lah, no more creaking sound!
    but after around 2 weeks, im starting to hear some slight creaking again, so last night i put oil on the studs, and no more noise. so my conclusion, the studs are the one making those creaking sound...
  • 02-20-2015
    emejay
    What solved it:
    This worked for me....I greased the cassette as described, torqued her on good, and its been silent for well over 500 miles now.
  • 03-05-2015
    seandm
    What grease are you all using on the cassette? I used some cheap tri-flow grease and that worked great for 1-2 rides, but the noise is starting to return.
  • 03-05-2015
    martinizer
    In trying to chase down the creak from hell on my HDR, and after exhausting the usual grease-the-crap-out-of-everthing-obvious routine, I:
    Replaced the cassette (under warranty),
    Greased every part of the rear mech, including the hanger until i ultimately replaced the derailleur (under warranty as it also had a clutch problem),
    Straightened the hanger
    Repacked the bottom bracket--twice
    Repacked the linkage bearings
    Lubed the spoke crosses on the rear wheel
    Tried a different seatpost
    Replaced the chain
    Tried different pedals
    Lubed the cable guides
    Adjusted the rear thru-axle mechanism
    Considered riding with headphones
    Nothing made a lasting difference. Then I decided to try lubing the hub pawls. As soon as I pulled off the XD driver the source of the noise was apparent. The sleeve that slides into the XD driver was bone dry and scored. Some light grease on the sleeve and a squirt of oil on the pawls and problem solved! Now all I can hear is my knees creaking.
  • 06-03-2016
    kaymonster
    Yep, those studs are the culprits...this was the solution for me too. Also noteworthy, seems they are extra susceptible to creaking if you've replaced the large ring.
    Sent from my SM-T800 using Tapatalk
