Results 1 to 5 of 5
    XX1 BB30 Crank Axle Length
    Has anyone measured the axle on XX1 BB30?
    Reputation: bikeguy0's Avatar
    It is shorter then the XO I can tell you that. It uses a thinner spacer between the BB and the drive side. I think it is about 5mm shorter.
    My Team: Feedback Sports Racing
    Quote Originally Posted by bikeguy0 View Post
    The spacer on the drive side is to lineup the chainline at 49mm. I'm more curious about the NDS. I've seen some BB30 cranks that have a huge spacer between the bearing and the arm interface. I see that XX1 BB30 has the bearing preload. How much slack can that adjust for? Is the axle threaded to use that adjuster?
    Yes axle is threaded for the preload adjuster. Maybe 3-5 mm adjustment available. There isn't spacers on the nds, just bearing shields if you have a pf30 frame.
    Can XX1 crank fit on a 83mm bb'd frame? I ask because the installation instruction show spacer arrangement with 83mm bb.
  1. SRAM XX1 BB30 Crank Axle Length???
    By ibis315 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2016, 12:31 PM
  2. BB30 crank on non-BB30 bike
    By reformed roadie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2013, 02:35 PM
  3. Replies: 6
    Last Post: 04-24-2012, 04:52 AM
  4. Best Deal on a BB30 Crank
    By foogotz in forum Where are the Best Deals?
    Last Post: 11-04-2011, 11:02 AM
  5. BB30 crank drag
    By moab63 in forum Cannondale
    Last Post: 10-12-2011, 02:37 AM
