Results 1 to 15 of 15
    XX, X0, X9 10-speed rear derailleur/shifter interchangeability/ compatibility..
    I would like to summarize here for everyone's benefit the interchangeability/ compatibility of SRAM XX, X0, X9 and X7 shifters and rear derailleurs- 10 SPEED.
    Which rear derailleurs work with which rear shifters and possibly what is the actuation ratio..
    (Example: SRAM AA rear derailleur works with SRAM AA and SRAM BB trigger shifters; actuation ration 1:1)
    Please post only if you know for SURE (not to confuse the rest of folks) :-)
    Thanks !
    West Chester, PA
    All of the sram 10 speed shifters and rear der. are interchangeable. X5 to XX
    CHOP!
    Reputation: MartinsMental's Avatar
    Dec 2005
    Quote Originally Posted by 92gli View Post
    FTW
    Thread over...
    It's not where it's made but how it's made.
    Quote Originally Posted by MartinsMental View Post
    FTW
    Thread over...
    Thanks for the comment mate ! very useful !!
    ji... for advise,,,, for sram xx crank 42X 28 , what is the compatible cassett size..11 X 32 or 11 X 36.....? thanks....
    Huckin' trails
    Reputation: David C's Avatar
    Quote Originally Posted by carbonbike View Post
    I think it would be 15 x 35
    SRSLY ? why would any of those 2 cassette not work as long as you get the proper rd cage length and right chain length ?
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    hi ,,,david ,,thanks..
    am using sram xx medium cage... chain yet to decide also,,, coz am changing from 3x10 speed..thanks..
    Huckin' trails
    Well you then just replace the crank and shorten the chain... Unless you also want to get a new cassette and chain with your new crank ?
    can you use 10 speed rear derailleur on x7 9 speed shifter?
    Reputation: madsedan's Avatar
    Aug 2010
    Quote Originally Posted by pinoiryder View Post
    Nope, 9 speed to 9 speed and 10 speed to 10 speed.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    Jan 2005
    Is the Sram xx1 rear derailleur (only) compatible w/ xx shifters and 10 sp chain, or does XX1 derailleur use a different acutation/cable pull ratio thus rendering the xx 10 speed chain and shifters un-usable. Note: I am not talking about using any other XX1 components, cassette, etc. The objective is that i ma replacing my worn out XX rear derailleur and would like to use the XX1 clutch rear derailleur as the replacement, as I will be running a 1x10 drivetrain.
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    Is this real life?
    Oct 2013
    Quote Originally Posted by buggymancan View Post
    The derailleur functions completely different then a normal 10sp. derailleur.
    11sp has to stick with 11sp. 10sp with 10sp 9sp with 9sp etc...
    Aug 2010
    Has anyone exact information concerning xx1\x01 derailleurs real ratio?
    I mean - will they work on 10-speed with shimano 10 speed triggers, like 9speed sram derailleurs do?
    Aug 2010
    At last I bought x01 rear derailleur and received following results:
    x01 ratio is 1:1 as sram 9speed or shimano 10speed.
    x01 works good with 10speed cassette and 10speed SLX shifter, and I think, the same will be with 9speed cassette and 9speed sram shifter.
    So, it is possible to buy x01\xx1 derailleur and cassette extender for 10speed cassette only and save some money...
  1. Getting a new rear derailleur!
    By Ram4.0 in forum General Discussion
    Last Post: 01-19-2012, 03:20 AM
  2. Advice on Crankset and Cassette for 24 Speed 1990's Titanium Hardtail
    By uraso in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2012, 10:37 AM
  3. 9 Speed MTB Shifters + Cassette, 10 Speed Road Rear Deraileur....??
    By joehspicer@msn.com in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-09-2012, 08:42 PM
