Here's an article about the new XO,X-9 and X-7 rings coming out, I talked to SRAM support and was told that it should be the same chainring bolt pattern as your XX, but the are not available yet , there will have the following combos available 22/36 and 24/38 http://www.bikerumor.com/2011/04/20...itional-2x10-gearing-ranges-derailleur-sizes/
The smallest inner ring that fits on an XX bolt pattern is a 26t, the 22 and 24 tooth inner rings will be for a spider that uses a 64/104 bolt pattern.
no, xx crankarms have an integrated carbon spider, it can not be removed.
if you must have xx crankarms and smaller than 26/39 rings you can go with aftermarket rings. some manufacturers make 25/38...CarbonTi springs to mind.
Thank you! Apollo Components got me headed in the right direction and chainrings are on their way...
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
