Results 1 to 7 of 7
Thread: X5 upgrade
    Sep 2013
    X5 upgrade
    Today the SRAM X5 rear derailleur fell to bits do I'm thinking of changing to X7. Does anybody know if this will work with the X5 shifter. And would I need a long med or short cage?. I don't want to spend more than I have to. Just want to be able to use my bike again. Front sprocket is 44/32/22T cassette is 11-32T. Thanks guys
    Reputation: Aresab's Avatar
    Yes, the only thing is if you have 9 speed you have to buy a 9 speed (also works with 7&8 speed as well), similarly 10 speed only works with 10 speed. Any 9-speed X3-X0 rdr will work with 9 speed X-5 shifters. Any 10-speed X-5 - X0 rdr will work with 10-speed X5.
    Sep 2013
    Ok cheers. What about the cage size though?
    Cage length goes by the total teeth, in general long for 3 rings, medium for 2 rings in on the crankset. But, for an accurate measurement, subtract the total teeth on the crank and cassette. 37t and below is ok for a medium cage, anything higher you need a long cage or you will not be able to keep chain tension in all gears. An example:
    Cassette : 36-12 = 24
    Crankset: 42-22=20
    Total difference is 44 and a long cage is required.
    If you have 2 rings and a bash, the same formula applies.
    Sep 2013
    I have three rings on front. With the teeth numbers I gave above. Wanted to go with medium cage for better shifts but not sure if it could cause damage with the teeth I have.
    I recommend a long cage. You could get a medium to work, but there will be gears that the chain will be very slack and droop quite a bit as well as some gears that the chain will be very taught. You have 41t difference and a medium is good to 37t.
    Sep 2013
    I went and bought a large cage but it was much bigger than the one I removed. So I returned it. Was going to try find a medium. I can't understand why it was a smaller one in my bike if it is supposed to be long cage for the amount of teeth I'm running. Chees
  1. Replies: 11
    Last Post: 06-06-2012, 01:41 PM
  2. Tora 318 fork upgrade.. What to upgrade to?
    By chadalex78 in forum General Discussion
    Last Post: 02-08-2012, 08:42 PM
  3. upgrade?
    By hwy1strat in forum Bike and Frame discussion
    Last Post: 09-20-2011, 04:29 PM
  4. Your First Mod or Upgrade
    By MTBkitty in forum General Discussion
    Last Post: 02-20-2011, 02:33 PM
