Results 1 to 8 of 8
    x1 rear derailleur b screw measurement question
    how do you guys go about measuring this? the manual says 12-15mm iirc.
    do i just change gears to my lowest gear then measure the lowest cog tooth to the pulley?
    2017 yeti sb6c turq x01 eagle
    RAKC
    Reputation: tigris99's Avatar
    Omg 12-15mm clearance from big cog to upper jockey wheel.... Everything I know (and though I use Shimano it isn't really any different) is usually around a few mm. I set mine by just adjusting it closer till the chain has trouble/drags getting into big ring then back off little at a time just till it smoothes out. Usually end up around 4-5mm clearance. You can't "measure" unless chain is off which to me is was too much hassle. My method takes 5 minutes and I have perfect shifting top to bottom. Never needed adjust once set.
    I would thing the distance your wanting would kill shifting at the bottom of the cassette.
    Quote Originally Posted by tigris99 View Post
    a few mms really? wow let me check the manual cuz i would've sworn it was 12-15mm.
    RAKC
    http://www.parktool.com/blog/repair-...icle-section-5
    Had to find the Link, but there's how you do it from Park.
    Rear Derailleur Adjustment - Park Tool
    ok i'll take a look. here's the manual for sram x1 rear derailleurs. see im not crazy lol
    RAKC
    Ya your not crazy, for some reason sram says set the x series further away, the others are about right, just a few mm. Must be something different with the way they function that they need to be further away.
    Still just eyeball it, no need to get all technical, promise you even an lbs just sets it by eyeball, nothing more
    i just eye ball mine cuz its hard to get a ruler up in there lol.
    i only brought this up cuz my friend installed an x1 derailleur yesterday and asked why it's 12-16mm. i have no idea why, i just know thats what the manual says. ty
    Reputation: mtnbiker1973's Avatar
    I can tell you from experience that 12-16mm is indeed correct. I had a noisy drive train until i properly adjusted the B screw. It didn't completely fix it, but it did make it better.
  1. Question regarding rear derailleur and rear brakes
    By Kerrslight in forum 29er Components
    Last Post: 08-11-2015, 03:01 PM
  2. SRAM X0 Rear derailleur limit screw busted
    By Mountain Medic in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-10-2015, 10:17 AM
  3. Rear Derailleur B Set Screw Stripped?
    By keenan88 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-07-2014, 08:53 PM
  4. Rear derailleur High limit screw issues
    By skinnyguy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-22-2014, 06:28 PM
  5. Replies: 4
    Last Post: 09-10-2013, 02:00 PM
