Page 10 of 10 FirstFirst ... 6 7 8 9 10
Results 226 to 242 of 242
  1. #226
    May 2005
    North Shore Billet
    Don't forget about the replacement 2x10 104 BCD spider from North Shore Billet for $70.
    2 x10 104BCD Spider for SRAM X0 & X9 Cranks North Shore Billet
    2013 Banshee Spitfire V2 650b
  2. #227
    Hi all
    I currently have a s-2200 crank fitted with a 38t 24t (104/64) with bashguard on my specialized fsr camber bike, I have always struggled with the 38t and would like to reduce it down a little.
    Ideally I have been told that the 36t would be fine i was wondering about 34t but i have been advised that this is not available. My question is can i just change the 38t to a 36t and leave the 24t or do i have to also change that to 22t as at the moment the 24t is just fine.
    Also the bike is fitted with an Sram x.7 front derailluer which is direct mounted S3 DMD bottom pull I believe will this be ok with a 36t ring also if it is would the chain also need to be reduced and if so how many links would you recommend.
  3. #228
    Reputation: craigstr's Avatar
    Sep 2003
    36 tooth should work fine without changing to a 22, you might reduce the chain by two links (equal to how many teeth you reduced your front ring) or just leave it alone and see if you notice any issues.
  4. #229
    cool thanks very much
  5. #230
    I have an S2200 crankset BB30 (22/36/bash) and I would like to convert this to a traditional 2x10 (26/39). Is this possible? Do I just need the spider and chainrings?
  6. #231
    Reputation: cryde's Avatar
    Oct 2007
    Resurrecting.....Looking at getting the 38/24 with bash.
    Any thoughts on taking the bash ring off and re-using the chainring bolts from the 39/26 chainrings?
    Would they fit and be the correct length?
    You gotta Get Up to Get Down!
  7. #232
    dat
    dat is offline
    Dec 2004
    Quote Originally Posted by cryde View Post
    You will need to get a new set of shorter bolts
  8. #233
    Oct 2007
    I guess that's kind of what I am asking. Are the bolts that currently hold my 39/26 chainrings together 'shorter' than the bolts that come with the 38/24/bash?
    The 39/26 is just the spider arms and then the two chain rings....by reusing those bolts I'm thinking it would get me the same thing when I take the bash guard off with the new chainrings.
    Guess I'll have to try it and see.
  9. #234
    May 2005
    I have a 24/28/bash off a bike right now so I can give you some dimensions.
    The shoulder section that goes through the bash and spider from the front is 7mm and the total width is 9mm including the head. The threads of the screw that goes into the shoulder section from the back side of the big ring are 5mm and the total width is 7mm.
    Compare that to your setup with just the ring/spider. Pretty sure you need longer bolt setup as I bought this combo to replace the original 26/39/spider (with no bash) that came on my now sold Jamis Dakar B2 (I put those original rings back on when I sold it keeping the (IMO) more desirable spider/24/38/bash.
  10. #235
    Oct 2007
    Thanks skidad. I'll check it out.
  11. #236
    anyone tried changing your 38T to 34 or 36T will maintaining the 24T granny gear?
  12. #237
    beater
    Reputation: evasive's Avatar
    Feb 2005
    X0 2x10 22/36 and 24/38 chainring availability?
    Yes, I swapped the 38 for a 36. I like the 24/36 combination.
    "Back off, man. I'm a scientist." - Dr. Peter Venkman
    Riding in Helena? Everything you need to know, right here.
  13. #238
    Evasive, u stick to sram chainring or 3rd party?
  14. #239
    beater
    Feb 2005
    Quote Originally Posted by ali_g View Post
    Race Face. I bought a 36t Turbine ring from my LBS and swapped them before installing the crankset. It works perfectly.
  15. #240
    Quote Originally Posted by evasive View Post
    Did you select the chainring with truvativ 4 bolt option? ever consider going down to 34?
  16. #241
    beater
    Feb 2005
    I'm not sure what that option is. I just grabbed a 10 speed, 36 tooth (104 BCD) off the shop wall.
    I've thought about a 34. I wanted one up until maybe June, but then I was strong enough that I was doing a lot of climbing in 36/36 and dropping several cogs to climb dirt roads, even with my mid-30s AM beast with 29er Minions. I'm due for a new chainring, and I'm debating buying a 34 to get me through the first couple months of next year. We'll see. With a 34 I would spend a LOT more time in the big ring, which has some advantages. I'd only ever spin out on roads.
  17. #242
    I'm going to ask this question 1 more time. Is the chainline for the 22/36 64/104 w/bash the same as the 80/120 w/ out bash Thanks
