Results 1 to 3 of 3
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    X-Actuation and Exact Actuation
    who is able to explain me the differences between X-Actuation of XX1 tramsmission and the Exact actuation of road Sram parts ?
    i need to know if the S700 hydraulic disc brake set works with a XX1 rear deraillaur.
    yes S700 is 10 speeds. XX1 is 11 speeds
    i already know that it works with a CX1 rear derailleur.
    is the cable movement able to manage a 10 speeds cassette ?
    i need it for a road bike set up 1x10
    Quote Originally Posted by eliflap View Post
    It won't work as far as I know. XX1 and X01 are the outliers, any other SRAM derailleur should work as long as it has the capacity for whatever size cassette you intend to use.
    FIRENZE rulez !!
    mmm i asked a question on Sram page on FB
    they replied me cable pull ratio is different .
    Quote Originally Posted by spsoon View Post
    to reply : i installed a X.0 9 speed derailleurs ( so able to manage a 34T cassette only ) with custom gripshift 2x10 , some years ago, with XX 11-36T cassette...
  1. Do older sram x9 3x10 shifters use exact actuation?
    By GuitsBoy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-09-2014, 02:51 PM
  2. Fox Float RP23 exact size
    By Atombike in forum Shocks and Suspension
    Last Post: 07-11-2014, 03:33 PM
  3. New sram deraillers, same actuation ratio??
    By wantnewbike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-22-2014, 02:45 PM
  4. where can I buy this exact....
    By bt in forum 29er Components
    Last Post: 07-09-2012, 10:21 PM
  5. Can I run an SRAM "exact actuation" front derailleur with a Shimano shifter?
    By ljsmith in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2012, 08:49 AM
