    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    SRAM XX1/X01 X-HORIZON Rear Derailleur questions
    Two questions about the SRAM XX1/X01 X-HORIZON Rear Derailleur:
    1) How many gears can you shift at a time?
    2) Can you ride with the clutch mechanism disengaged?
    I'm particularly interested in the answer to question 1; because I like to use a grip shifter so I can grab/dump a lot of gears at once. I've heard that SRAM's clutch derailleurs limit you to one gear at a time.
    Thanks in advance for your help!
    "sounds like you need to find a better mechanic..." -- Calhoun
    Apr 2005
    1) depends on which direction
    2) no
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    1) With the grip shift you can rip thru all the gears at once if you want. With the trigger you can up shift 4 at once, but down shift 1 at a time.
    2) Yes, but it is not as simple to do at the Shimano stuff. You have to open it up.
    14 Aurum, 16 Fuse, 17 T130
    Aug 2010
    I much prefer the Shimano trigger shifters because you can go down 2 smaller cogs with one push. You also get instant release, plus dual release, and the ergonomics feel a lot better to me.
    I recently got a new bike with XX1 trigger, and I want to switch to the grip shifter. They are very expensive, though, and I've heard of some reliability issues with the XX1 grip shifters.
  1. Replies: 0
    Last Post: 03-28-2013, 04:05 AM
  2. XT rear derailleur vs. SRAM X9
    By htjunkie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-06-2013, 08:31 AM
  3. Sram XX1 X Horizon RD as a 10 speed?
    By Sand Rat in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-15-2013, 06:13 PM
  4. sram x-9 rear derailleur questions
    By t_roy in forum Specialized
    Last Post: 10-01-2011, 01:31 AM
  5. SRAM X0 rear derailleur
    By ehigh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-25-2011, 03:55 PM
