Results 1 to 3 of 3
    May 2005
    SRAM XX ring GXP vs BB30
    What is the difference between a 39th GXP and 39th BB30?
    Can I use a 39th GXP on a BB30 crank??
    Reputation: Alexgonzalezmi's Avatar
    The qfactor of the cranks are different but that has no bearing in the rings so you could use them as they are the same.
    I'm Slow
    Reputation: paulrb02's Avatar
    XX Chainring Questions & Swap with a X.0 Chainring Possible?
    Basically its the outside pin, its different because of the different Q-factors
    RideSAMBA.com Mountain Biking in South Alabama.
  1. Difference in SRAM GXP and BB30 Spider?
    By dubjay in forum SRAM
    Last Post: 05-24-2014, 02:29 PM
  2. Using a SRAM XX GXP Crank in a BB30 Frame
    By flafonta in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-15-2011, 08:18 AM
  3. Flash and Sram XX BB30 Crank
    By roadrunner in forum Cannondale
    Last Post: 06-13-2011, 02:16 PM
  4. Flash 29'er 1 and Sram X.O. BB30 Crank
    By Blade-Runner in forum Cannondale
    Last Post: 04-12-2011, 09:47 AM
  5. FSA BB30 vs SRAM XX
    By Nick_S_Africa in forum Cannondale
    Last Post: 02-20-2010, 03:19 AM
