Results 1 to 5 of 5
    Oct 2011
    SRAM X7 Crank coming loose...
    After downloading the tech manual from the SRAM www I see that there is a lock screw on the left side crank.
    After adjusting to SRAMīs specs and a 30 mile ride the crank has come loose for the third time on a new bike (less than a hundred miles)
    Anyone have same issues? Is this a warranty claim? If not, is it an excessive grease problem on the 10mm bolt?
    Help would be greatly appreciated!
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    Have you installed it using proper torque and Loctite threadlock?
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    Oct 2011
    I haven't taken it apart, the Tech guide does not mention loctite. It has been tightened to 50NM and then adjusted the left side to "hand tight".
    If it is not a warranty issue I will take it apart to see if it was greased by accident during the original build.
    Regards...
    Mar 2006
    Following the manual and assuming you're on PF/BB30 cranks:
    Thread the bearing preload adjuster all the way on (the plastic collar on the left side)
    Install he left arm/spindle
    Tap it over lightly with a rubber mallet toward the driveside.
    install the driveside spacer
    install the right side crankarm, adequate grease on threads and spline surfaces.
    Torque right side crankarm bolt with a reliable torque wrench to spec.
    now tap the right side crank lightly with a rubber mallet to get the remaining gap consolidated on the non driveside.
    Adjust the collar to take up the gap, about another 1/8 turn to add proper preload.
    Tighten the collar clamp screw until the split in the collar is closed.
    Should hold up fine.
    Might be worth re-torquing the driveside after a 10 minute ride around the neighborhood.
    Oct 2011
    Quote Originally Posted by rammer View Post
    Yep thatīs pretty much it!
    In the last couple of days I have gotten in a really good trail ride, mostly DH but to go down ya gotta go up...
    Main point: After about 110 miles no further problems. Will keep thread updated with any further maintenance required.
    Best regards and Happy Holidays to all.
  1. crank arm keeps coming loose
    By Gilly32 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-11-2011, 06:57 AM
  2. Right crank coming loose
    By scott0482 in forum Beginner's Corner
    Last Post: 04-16-2011, 06:06 PM
  3. Crank Keeps coming loose......
    By ae111black in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-17-2010, 06:53 PM
  4. Crank keeps coming loose
    By mushypeas in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-16-2005, 12:50 PM
  5. Truvativ Crank arm keeps coming loose
    By Haystack Calhoun in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-27-2004, 09:43 AM
