Results 1 to 2 of 2
    Jan 2011
    Sram X5 front derailliur, X9 shifter
    Hi.
    Ive just had a hell of a time replacing my x5 rear derailliure for an X0 and an X9 shifter, but after many hours i think I've finlly got it dialled in, however I still have the X5 front derailliur and shifter. All I plan to change now it the shifter for a matching X9 shifter and Ive just been told that the X9 shifter will not work well with the X5 front derailiure.
    I personally cant see why this would be the case, but just thought I would check with the people in the know before I go screwing up my bike even more
    Huckin' trails
    Reputation: David C's Avatar
    If your X-5 fd is for a 8 or 9 speed drivetrain and your X-9 front shifter is also for a 8-9 speed drivetrain, well no problem. If you use a 10 speed drivetrain, you will need a 10 speed fd and a 10 speed front shifter, since the spacing for a 10 speed crank is narrower then a 8 or 9 speed, so your fd has to move differently and means that the front shifter has to pull a different amount of cable then the 8-9 speed one does.
    Otherwise I've never heard of that problem.
    David
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
  1. replacing sram front shifter
    By fulanito in forum Beginner's Corner
    Last Post: 07-10-2010, 10:05 AM
  2. SRAM X9 front shifter won't pull cable?
    By bscruz in forum SRAM
    Last Post: 06-10-2009, 10:08 AM
  3. Locked Up SRAM X.O Front Shifter?
    By Lunger in forum SRAM
    Last Post: 06-28-2007, 05:14 AM
  4. Sram Front Shifter - don't like it!
    By energetix in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-22-2006, 05:09 PM
  5. front sram shifter, click 3 times? or more?
    By Kelvin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-31-2004, 07:15 PM
