    SRAM predictive steering hub flange diameter?
    Mundane question but not satisfied after online hunting. SRAM plans to sell these hubs but does not include the key info for building a wheel.
    Reputation: shiggy's Avatar
    Dec 1998
    Even if they post the specs you need to measure the hub yourself.
    mtbtires.com
    Whatever
    Reputation: MINImtnbiker's Avatar
    Here is what SRAM says:
    SRAM predictive steering hub flange diameter?-sram-predictive-steering-hub.jpg
    Disc side flange diameter: 50mm
    Drive side flange diameter: 46mm
    Disc side to center: 26mm
    Drive side to center: 34mm
    Spoke hole diameter: 2.7mm
    https://sram-cdn-pull-zone-gsdesign....0000004718.pdf
    just ride
    Dec 1998
    Re: SRAM predictive steering hub flange diameter?
    Quote Originally Posted by MINImtnbiker View Post
Name:	SRAM Predictive Steering Hub.JPG
    And I still would never buy spokes until I had measured the hub myself.
    mtbtires.com
  1. Chris King ISO 15 mm front hub -- Small Diameter or Large Diameter?
    By Flat Again??? in forum Wheels and Tires
    Last Post: 07-10-2013, 11:57 AM
  2. TT diameter larger than ST diameter
    By golden boy in forum Frame Building
    Last Post: 08-28-2012, 05:31 AM
  3. SLX M665 Rear Hub Flange Diameter
    By BobShort in forum Wheels and Tires
    Last Post: 12-16-2011, 08:07 AM
  4. flange diameters...
    By John S in forum Shimano
    Last Post: 07-10-2011, 05:28 PM
  5. Steering Tube Diameter
    By webbaldo in forum Marin
    Last Post: 03-16-2011, 07:04 PM
