Results 1 to 7 of 7
    Mar 2014
    SRAM MTH 716 hub - missing end cap?
    I was fooling around with the GFs new bike trying to get the front brake caliper centered a little better and came across this..
    Unfortunately the 716 isn't very common aftermarket, but it is used on most of santa cruz's bikes from what i can tell.
    is it ok for there to be no end cap like that?
    Aug 2015
    Sorry to revive. Did you find out how to get the end cap. I have same problem, noticed too much play in front wheel. Looked down and saw exposed bearing.
    Mar 2014
    Nope. Had to buy a new hub. I still have the rest of the hub somewhere, with one of the endcaps still attached. I just don't remeber if I brought it with me when I moved 7 months ago. It's really bugging me now that I can't find it.
    Aug 2015
    Are the end caps easy to remove? just slip on?
    Mar 2014
    Yep. Only thing really holding them on is a bit of grease and they slip onto the axle tube.
    Aug 2015
    Thanks impulse! Will try to source a spare hub.
    Sorry to revive this thread...
    Quote Originally Posted by Impulse922 View Post
    Does anyone know if the end cap is the same as is used on SRAM Rise 40 front hubs?
    SRAM Rise 40 Front Wheel QR Axle End Caps | eBay
  1. Replies: 25
    Last Post: 01-22-2014, 11:43 AM
  2. delete
    By morkys in forum Shocks and Suspension
    Last Post: 05-13-2013, 11:01 AM
  3. Sram crank spindle slop. What is missing?
    By melonheaded in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-01-2012, 05:20 AM
  4. New SRAM 2x10 X0 Chainring - missing chain drop pin?
    By Burning Matches in forum SRAM
    Last Post: 10-13-2011, 07:51 PM
  5. Sram X9 Missing Anchor Bolt Problem
    By kermit_xc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2011, 07:11 PM
