Results 1 to 9 of 9
    Jan 2011
    sram Double tap flatbar shifter's FD compatibility
    title kinda says a lot, well heck it says it all...
    what Mountain FD can I use with these SRAM Double-Tap Flat-bar shifters?
    http://www.sram.com/sram/road/produc...-road-shifters
    Or is this a case were I am forced to use a Road specific front Derailleur?
    It's a on/off cruiser project i had on going for the better part of this summer, trying to get an old 92' Trek 950 drive worthy again...
    (yeaH She's old, but she was my first and I just can't let her go...)
    And No my Yeti Seven isn't jealous at all of her...
    I have had success setting up the rear Derailleur with an X.9 9-speed Mountain Derailleur...
    But the front has proved to be tricky, I need a Front D compatible with Double -Tap Tech and a 1:1 ratio...
    ANY THOUGHTS GURU'S!!
    thanks in advance...
    Jan 2011
    bumpity bUMPITY bUMp....
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    My wife is running the 2 x 10 Double Tap shifters with Sram X9 rear & X9 front derailier's
    Quote Originally Posted by toast33 View Post
    I have a 6 Berth Motorhome that I rent out . It is based in Tauranga, New Zealand
    Jan 2011
    OK, Thanks, I had initially tried an X.7 FD and it completely fubar'd.... Appreciate it!!
    No longer 26
    Reputation: G-Live's Avatar
    Quote Originally Posted by muzzanic View Post
    How does it work? I have been tempted to try double tap with a 2x10 system. Or even just the front on my 2x9 (using a 10 spd chain). I think I'd really like it for front shifts if I could get a hold of a front shifter fairly cheap-ish
    G
    You can't depend on honest answers from dependant hands...
    Jan 2011
    I'm running the 3 x 9 setup and it works great as a commuter setup... That said here's what I've learned.... It requires 1:1 actuation ratio Derailluers, ( so X 9 or higher). Second while it is Very accurate, it could be touchy in rough terrain... Since it depends on how far you depress the singlr lever... A mis-shift could be easier too make while going over a rooted area or on a rough singletrack... I love it on my commuter, but my FS asr7 has full X 0 package and the shifter's are second to none... Good luck
    May 2010
    Did this end up working for you? I want to try SRAM Rival brifters on a mountain double, and am wondering what to do to make it work, if it is even possible at all.
    Jan 2011
    Yes, but only with x9 derailleurs or above.. X7 had a uncompatible ratio, so if the shifters your using have the same ratio as the dbl taps then all should work for your setup...
    GL. Post results if you get a chance!
    pedal pusher
    Reputation: f3rg's Avatar
    I have an X.9 RD, and want to use it with 10sp SRAM Rival or Force brifters.
    Are you saying this set-up will actually work w/o some sort of in-line adapters, etc.? If so, it'd make this project I'm working on a lot easier.
    The X.9 is a few years older, maybe a 2008 or '09 model, by the way.
  1. Spring Compatibility for Cane Creek Double Barrel
    By intsikko in forum Shocks and Suspension
    Last Post: 12-06-2010, 06:49 PM
  2. XO Grip Shifter's Life Span.......
    By durkind in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2010, 03:35 AM
  3. SRAM X.O Compatibility XT?
    By smokinjoe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-12-2010, 07:39 PM
  4. Flatbar Shifters Shimano SL-R770 vs Sram Double Tap
    By ironhorse1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-03-2009, 05:04 AM
  5. sram flatbar doubletap shifter question
    By esilvassy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2009, 03:44 PM
