Results 1 to 3 of 3
    Reputation: bluechair84's Avatar
    Sram Crank owners please; What's your Q-factor?
    Hi all, I'm in the process of designing a frame which requires a particularly wide crankset. First off; by Q-Factor I mean the distance between the inside faces of the cranks. Some places seem to measure to the outside faces which is entirely useless as it doesn't tell you stance width (how far apart your feet are) or the clearance the cranks give from the stays.
    Anyway, the current batch of X9/7/5 are listed on their technical doc as being 171mm which seems rather large, when Shimano are about 150mm. If this Q-Factor is correct, I'm very very happy, and will be speccing Sram cranks on the design. But I get a funny feeling they're measuring to the outside face which will make them narrower than Shimano.
    So - any measurements would be greatly appreciated!
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    I know SRAM makes XX/X0 cranksets with 156 and 168 Q-factors.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Yup, and they seem like reasonable figures as if those numbers were the outside faces, I doubt they'd clear many frames. But the 171mm X9 I'm holding out for seem like the figure could be an error in the doc. Another forum I found whilst Googling showed quite a few errors in their tech docs. Plus, the X0 are a bit on the pricey side for me. If the 171 X9 is a fallacy, they will have to be the cranks.
  1. Which q factor XX1 crank?
    By limba in forum SRAM
    Last Post: 12-30-2012, 03:47 PM
  2. E.13 crank Q factor
    By PoorCyclist in forum Singlespeed
    Last Post: 08-15-2011, 12:27 AM
  3. Replies: 5
    Last Post: 05-08-2011, 06:37 PM
  4. Sram XX on a Anthem X, crank q factor?
    By Rick Draper in forum Giant
    Last Post: 04-22-2011, 12:28 PM
  5. Sram XX 156 Q factor crank on a Air 9 ?
    By Anthem1 in forum Niner Bikes
    Last Post: 03-27-2011, 07:42 PM
