Results 1 to 3 of 3
    SRAM BB30 XO carbon crank looseness
    At a loss here on this one and can't find much in the search. My XO BB30 carbon crank is loosening on every ride even after torquing with a torque wrench.
    Setup is correct according to SRAM'S hieroglyphic instructions; however it almost seems as though there is a spacer in place that shouldn't be there. From the non-DS:
    Crank arm > lock ring > bearing sleeve > bearings > axle > DS bearing > bearing sleeve > 10mm spacer > DS crankarm.
    Once the DS crankarm is torqued, I tighten the collar on the non-DS. Is there something I'm missing here?
    The bike is a Lynskey PRO29SL with a PF30 shell.
    Sent from my SM-G930V using Tapatalk
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    That all sounds correct, assuming you're using a SRAM PF30 bottom bracket. Have you confirmed that your bottom bracket shell is 73mm? If its 68mm then you need additional spacers on each side. Also are you making sure the DS crankarm is fully seated by gently tapping it with a rubber hammer before you tighten the bolt?
    Thanks for the reply. It is definitely a 73mm shell. I broke down and went in to the shop. The shop set it up with some green loctite and retorqued. So far so good. We'll see what happens.
  1. Replies: 1
    Last Post: 01-29-2016, 07:16 AM
  2. SRAM XX BB30 or GXP crank for BB90 BB ???
    By sooza in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2014, 06:51 PM
  3. SRAM BB30 crank in MTB OSBB help
    By tootall in forum Specialized
    Last Post: 10-22-2012, 11:11 AM
  4. Using a SRAM XX GXP Crank in a BB30 Frame
    By flafonta in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-15-2011, 08:18 AM
  5. Flash and Sram XX BB30 Crank
    By roadrunner in forum Cannondale
    Last Post: 06-13-2011, 02:16 PM
