Results 1 to 2 of 2
    RS Reverb requires constant bleeding
    Dear all,
    after years on very simplified SS rigid bikes, I recently decided to build a full suss. I bought a Reverb seatpost for this bike (2014 stealth version) and installed it (had to shorten the hose which I believe worked out fine). Since I installed it around two weeks ago, I constantly need to bleed it because the post is not lowering/coming up. After bleeding, everythings works flawless. I don' t even use the bike at the moment because I'm still waiting for some other parts, so this happens on a brand new reverb that is not even in real use. I just try it out every other day, and it seems to suck air within 2-3 days??!!
    Any ideas what could be wrong?
    thanks for your help
    Björn
    Reputation: cort's Avatar
    Bjorn
    I have already seen 6 brand-new 2014 Reverb Stealth's exhibit this problem. They all have been replaced with new seal kits and are now 100% functional.
    Since you have down-time, I would send this back to your warranty center for repair - now's the time to do it
  1. Rockshox Reverb Bleeding.
    By cabralkev in forum 29er Components
    Last Post: 10-08-2013, 12:09 PM
  2. Rock Shox Reverb / Reverb Stealth
    By WorldIRC in forum Trek
    Last Post: 07-01-2013, 07:12 PM
  3. Lyrik 2step too stiff / requires low psi
    By DirtyMartini in forum Shocks and Suspension
    Last Post: 04-09-2011, 04:21 PM
  4. First time 29er buyer requires help
    By Evil_Scotty in forum 29er Bikes
    Last Post: 04-01-2011, 05:48 PM
  5. Cog change requires how much adjustment?
    By BrianU in forum Singlespeed
    Last Post: 01-24-2011, 09:44 AM
