Results 1 to 2 of 2
    Aug 2014
    Reverb play. Any advice?
    I have a stealth reverb that came on the bike I purchased new earlier this year. It has recently developed vertical play. That is there is about 7mm of travel whenever I sit down like one of those terrible old suspension posts. This is a small amount but believe me it is enough to be annoying. I've bleed the system with no improvement. If this is just 'wear' I have to say I'm disappointed i should be able to get more than 1300 miles out of a dropper. Any advice would be appreciated
    Aug 2010
    Your post is fine. You need to replace a couple 10 cent o-rings on the inside of the post. They have gone bad. In addition, it wouldn't surprise me if your inner seal head has started to unscrew itself. Thankfully, SRAM made a really nice rebuild manual on the reverb stealth. You can download it from their site.
  1. Reverb won't hold full pressure - vertical play
    By brightsky in forum All Mountain
    Last Post: 09-30-2013, 10:00 PM
  2. Rock Shox Reverb / Reverb Stealth
    By WorldIRC in forum Trek
    Last Post: 07-01-2013, 07:12 PM
  3. Play in my Reverb...opinions
    By mastakilla in forum All Mountain
    Last Post: 01-20-2012, 04:31 PM
  4. Easton Havoc AM - play in rear hub. Expert advice needed.
    By y0bailey in forum Wheels and Tires
    Last Post: 07-25-2011, 08:08 PM
  5. Reverb from 31.6 to 30.9
    By Jingleman in forum SRAM
    Last Post: 02-17-2011, 09:09 AM
