    New question here. Is it possible to replace cage on XO rear derailleur?
    I bent the cage on my 2006 XO Rear Derailleur. I was wondering if it can be replaced. I am going to try and bend it back but if that fails I had to toss it. It's still works fine and too costly to replace.
    Reputation: Tiffster's Avatar
    If its bent i assume the cage is one of the alloy ones ?
    I answered the same question the other day - in the UK a new cage assembly including pulley wheels/bolts is about £75 or in the USA its over $100
    If you decide not to repair can you contact me as i need some spare parts please!
    *R*O*W*Y*C*O*
    Reputation: PUBCRAWL's Avatar
    Feb 2007
    New Carbon/Alloy replacement cage assemblies $87.00 from Universal Cycle in the USA.
    Almost the cost of replacement pulley wheels here in Canada...
    I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me.
    Hunter S. Thompson
    That's not too bad then. I'll keep that in mind as that would be cheap thanks to the exchange rate
