Results 1 to 3 of 3
    Pike air pressure question?
    I recently put a Pike Solo RCT3 26" on my new Enduro and it seems like the pressure has to run pretty low to get the sag right. According to the fork leg, for my weight I should be running about 65 psi. At 65 psi I'm at about 12% sag, if I bring the pressure down to around 57-60 I get the sag close to 20% but then I bottom the fork out on the bigger hits so I can't take the pressure down anymore. I've since added 1 volume spacer and my pressure is around 45 psi and sag is about 25%. It seems to be "ok" now but I'd like to get the sag closer to 28% but I feel like the air pressure is already so low. Basically what I'm asking (in a very long way) is it typical to run pressure that low on theses Pikes?
    James
    Quote Originally Posted by james_95 View Post
    James
    same here
    Reputation: IPunchCholla's Avatar
    Dec 2013
    Re: Pike air pressure question?
    James
    That sounds close to my set up at first. During the first 100 miles though the fork seemed to break in and I added more pressure to the point she I am running 25% sag and the pressure is close to the recommendation.
    2014 Devinci Troy Carbon XP
  1. Air pressure question
    By RS VR6 in forum 29er Bikes
    Last Post: 01-23-2014, 07:34 PM
  2. Pike owners.... what pressure are you running?
    By AZmtncycler in forum Niner Bikes
    Last Post: 01-15-2014, 02:36 PM
  3. Pike owners.... what pressure are you running?
    Last Post: 10-07-2013, 11:21 AM
  4. Question about RS Pike U-turn air oil/service
    By ride the biscuit in forum Shocks and Suspension
    Last Post: 12-20-2012, 04:48 AM
  5. Carbon 456 with Pike 426 Question
    By Merp in forum On One
    Last Post: 12-13-2011, 10:13 PM
