Results 1 to 2 of 2
    Pike 29 RCT3 - standard rotor size?
    Good morning,
    My Google-fu is failing me here and I'm hoping someone can help. I know the maximum rotor size for the Pike RCT3 29 is "200mm". My question is, what size rotors fit the Pike's posts out of the box without using adapters - 180mm? 203mm? I'm not sure.
    Thanks in advance.
    Mar 2005
    160 without adapter. I'm 95.1% sure that the post mount standard is 160mm rotor for all front and rear mounts on all bikes and forks unless specifically called out differently.
    Sent from my SCH-I545 using Tapatalk
  1. 2014 RS Pike Rotor Size
    By Dambala in forum Shocks and Suspension
    Last Post: 03-05-2014, 01:01 PM
  2. RockShox Pike RCT3 29 160mm
    By Scottandhisdog in forum SRAM
    Last Post: 02-13-2014, 09:26 AM
  3. RS Revelation RCT3 or Pike Solo Air
    By katen21 in forum Shocks and Suspension
    Last Post: 01-25-2014, 10:20 AM
  4. Pike Rotor Size
    By J_R_A in forum Brake Time
    Last Post: 02-13-2012, 08:35 PM
