Results 1 to 9 of 9
    No talent hack
    New Rock Shox Pike...
    RockShox Reincarnates the Pike, Updates Reverb Stealth and Monarch Plus - Bike Rumor
    So my only question.... can the travel be choked down closer to 120mm? My planned upgrade list includes replacing my Reba with a stouter fork and currently my ONLY option is the Fox 34 TALAS because of travel.....
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
    No talent hack
    I have read more. It looks like the 29" version will be 150mm dual position air.... that means it should be able to be reduced down toe 120mm, right? Anybody?
    May 2005
    If anyone comes across the A-C height and fork offset of these forks please post it up. Specifically I'm interested in the 27.5" fork but everything would be good to have.
    2013 Banshee Spitfire V2 650b
    fnInt(1/x^2,x,0,1)
    Reputation: fleanutz's Avatar
    I have a Pike, 29" of the 150mm - 120mm Dual Position variety. A-C height in what I assume is the 150mm mode is 565mm (center of thru-axle to crown race bottom).
    There is a stamp in the underside of the crown, part of which reads "45," which may the offset. Unsure.
    Reputation: MrPretty's Avatar
    Feb 2012
    I am also curious about lowering a pike to 120mm. I noticed that the new Specialized Camber EVO comes with a pike that is lowered to 120mm (via here)
    Does anyone know if this was something that was done just for Specialized, or can the non dual-position Pike be lowered to 120mm as well?
    Thanks.
    Reputation: jhtopilko's Avatar
    Oct 2012
    I am also interested in this for my Camber.
    No talent hack
    I guess I didn't post in the original post, but I also ride a Camber (2013 alloy Comp to be exact).... looks like some Pike equipped Cambers are going to be roaming the trails soon....
    You may have to shmooze your LBS parts guy a bit, but if the Camber Evo comes with the 120mm Pike, we will be able to get it too. I haven't stopped smiling since I saw that spec'd on the new Evo Carbon. Between the Pike and the Fox Kashima for the rear, I am a happy camper looking at the new 2014 bikes. Just be patient and talk to your people, at the very worst, they should be able to order the internals needed to convert a 140mm Pike to 120mm.
    Could you Internally boost the travel from 150mm to 160mm???
    No talent hack
    Quote Originally Posted by Fredo23 View Post
    RS Pike 29er 160 Fact or Fiction?
    Two threads down right now....
  1. HELP! Rock Shox Pike 327????
    By juancho142 in forum All Mountain
    Last Post: 09-05-2011, 07:34 PM
  2. Rock shox pike 327 clicking noise
    By FRhansen in forum Shocks and Suspension
    Last Post: 07-03-2011, 06:36 PM
  3. Pitch Comp & Rock Shox Pike
    By KBfromVT in forum Specialized
    Last Post: 05-10-2011, 11:27 AM
  4. Rock Shox Pike Line Up
    By ehadzima in forum Shocks and Suspension
    Last Post: 04-07-2011, 11:22 AM
  5. 2010 Fox Float 32 R or Rock Shox Pike Pushed?
    By Jaybo in forum Shocks and Suspension
    Last Post: 02-14-2011, 07:36 PM
