Results 1 to 2 of 2
    Moving X9 crank from GXP BB to Trek's press fit BB - what is needed?
    Hello! I'm moving over the X9 grouppo from a Trek X-Caliber frame that uses a std GXP BB to a new Trek Stache frame, which uses a press-fit BB. The BB bearings are in place. What is needed, adapters, spacers, etc, for the X9 crank to work with this BB?
    thanks
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    You don't need anything assuming the press fit bb is complete with the seals. Just stab it in and torque it to the recommended specs.
    That should help.
    http://cdn.sram.com/cdn/farfuture/SB...ranksets_0.pdf
