Results 1 to 8 of 8
    Nov 2008
    Monarch 2016 RT3 - no lockout
    All,
    I have a 2016 Monarch RT3, when in the trail and lockout positions there seems to be no difference. All positions seem to be open. Any tricks/tips to re-enable this? I may try and let out and re-air the shock later today.
    Frankly, I'm not sure it ever worked. I was on my ~20th ride yesterday, a long road climb, when I hit the switch... and nothing. Hehe.
    Reputation: vaer's Avatar
    Aug 2015
    Quote Originally Posted by lightenup View Post
    All,
    Not quite the same shock, but I've noticed my RT lockout doesn't seem to 'kick in' till the shock has cycled a couple of times after the lockout hasn't been used in a while (so if I lock it out and jump on it a couple of times it eventually gets hard, or if it just bobs for a bit)
    Nov 2008
    Quote Originally Posted by vaer View Post
    Took my bike into a knowledgeable shop. They had seen this before and suspected the damping circuit was completely dry. It has been sent away to SRAM, its been 1.5 weeks no word from them yet
    Aug 2015
    Hope you'll post back with the result from SRAM when you get it back. Mine seems to work fine as long as I kick it a bit, but might be a perform diem the line and would be interesting to reference back.
    Nov 2008
    Just got a tracking number. Ill post any info they provide.
    Nov 2008
    So sram said nothing was wrong, but they opened the shock and found a scratch. So they sent me a new shock with the wrong tune. They are sending out a new shock with the correct tune as we speak.
    My old shock was a LLS tune this one is a MMS. The floodgate lever at each setting has a noticeable and different feel which also and effects sag at each setting (as it should). So there was something wrong after all. I guess someone was having a bad day at Sram.
    Totally different shock. Sounds like your ifp pressure is low. Needs to be 450-500 psi.
    Nov 2008
    Got a new shock from Sram, with the correct tune (LLS), the floodgate lever presents a unique and different feel in each position (as it should). Case closed.
    Side note, its amazing how different the medium and low tune shocks felt. The medium made the rear end much firmer and was hard to use all the travel. I ran the medium tune with no rebound / no compression (totally open). It was okay, but make the bike (transition scout) feel like it had a xc oriented suspension.
    The low tune is much more plush and I can bottom the shock out a lot easier. I prefer the low tune in the open mode with a few clicks of rebound damping. For climbs, the floodgate lever is nice in the firmest position.
  1. Monarch RT3 autosag is not a true lockout?
    By Jose915 in forum Shocks and Suspension
    Last Post: 09-14-2015, 08:49 PM
  2. Monarch Plus RC3.. Does PSI effect lockout??
    By rickygmoney in forum Shocks and Suspension
    Last Post: 08-01-2015, 06:58 PM
  3. lockout delay in monarch?
    By amer_ua in forum Shocks and Suspension
    Last Post: 12-17-2014, 06:41 PM
  4. Monarch XX Lockout
    By jeddog69 in forum Cannondale
    Last Post: 01-16-2014, 10:01 AM
  5. Monarch xx lockout on scalpel
    By norty_mtb in forum Shocks and Suspension
    Last Post: 07-29-2013, 05:09 AM
