Results 1 to 5 of 5
    May 2010
    Matchmaker clamps keep cracking
    Is it just me or is this a common problem??? I have had two fail all on the front shifter I`m using xo two by10 with a x7 front mech full outer cable on a stumpy evo. They are the normal matchmaker clamps not matchmaker x
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    Were are they cracking? Pictures? Are you torquing them down too tight?
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    Aug 2010
    Quote Originally Posted by Ronstar View Post
    Unfortunately, this is a well known problem with the standard MM clamps. They are great little device in theory but the metal used is cheap stamped metal similar to something like matchbox car metal so they are rather flimsy. You can't use the quality "X" ones unless you run at least the X0 level brakes since they have the appropriate clamp type.
    COTA member
    Reputation: Dry Side's Avatar
    Yep had same problem so switched to individual SRAM clamps. Running X7 shifters and Elixir 3 brakes. No issues since. Elixir 7 brakes and better will work with MatchMaker XX clamp.
    May 2010
    Thanks guys I can`t run the matchmaker x using elixir cr has any one had them completely snap off?
  1. Have SRAM Matchmaker Clamps. Need Normal Clamps. Where?
    By nufenstein in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-18-2011, 10:04 AM
  2. Matchmaker X
    By ArcticCat500 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2011, 06:04 AM
  3. XX Matchmaker Clamps, Pic request
    By DekerfTeamST in forum SRAM
    Last Post: 04-19-2010, 12:24 PM
  4. SRAM XX Matchmaker clamps
    By pk1 in forum SRAM
    Last Post: 04-19-2010, 11:15 AM
  5. Matchmaker
    By AnthemRider in forum SRAM
    Last Post: 07-23-2007, 04:08 PM
