Results 1 to 9 of 9
    Feb 2005
    King GXP BB + XX1 Crank Won't Tighten Enough
    Installed a Chris King GXP version Bottom Bracket and am trying to install a XX1 crankset.
    All washers in place:
    • 4 black washers on drive-side
    • Spring washer on drive-side
    • Silver washer on non-drive side
    • Spacer over spindle end on non-drive side
    King GXP BB + XX1 Crank Won't Tighten Enough-photo-1-.jpgKing GXP BB + XX1 Crank Won't Tighten Enough-photo.jpg
    When I tighten the 8mm bolt, the bolt seems tightened and there is still considerable play. Any ideas what I'm doing wrong? I've scoured the threads here and only seem to find cases of non-GXP King BBs where the solution was to get the fit kit.
    Oct 2012
    I have the same setup. Did you include the disc spring after the 4 washers on the drive-side?
    Feb 2005
    Yup. I forgot to add that to the post though. I'll go edit.
    Thx
    Feb 2005
    Added pics up top. I'm fairly certain the order of everything is correct. However, if I made a mistake please let me know!
    Oct 2012
    Did you try the fitting test? Insert crank w/o bearing sleeves and outer edge of adapter sleeve should protrude from outside of bearing by 0.5mm. 0mm to 1mm is acceptable. If not within 1mm you would need to add/remove spacers. If you have a 68mm BB you would need to add a spacer. This is all I can come up with....good luck!
    Feb 2005
    I'm already using all 4 spacers that came with the BB. I guess I'll have to order more shims...
    Oct 2012
    Mine came with a couple of extra ones that were white. Also came with 2 2.5mm BB cup spacers for use on 68mm BB in between cup and BB.
    Feb 2005
    I'm using the two 2.5mm spacers (for 68mm shell). Curious if should move both to the drive side instead of the current config (1 on each side).
    Feb 2005
    I am so ashamed. When I removed the bearing spindle sleeves to fit check (per the instructions), I set these aside. Somehow, I forgot they existed.
    Sorry for wasting your time folks. Thank you for trying to help regardless!
  1. S2200 Crank Arm How to tighten properly
    By Tjay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-03-2013, 08:11 AM
  2. Chris King BB, will a Truvative Stylo crank fit?
    By cncwhiz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2012, 09:57 PM
  3. BB30 crank or adapter with King BB?
    By Jaybo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2012, 05:10 PM
  4. Replies: 1
    Last Post: 09-02-2011, 06:19 PM
  5. Sram XX gxp crank and Chris King Compatibility issue
    By 9nerd in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-11-2011, 08:21 PM
