    Aug 2017
    Help ! Want to change front ring size
    Hi all I have a 2018 trek fuel ex 7 with sram nx 1 x11 drivetrain but it has a 30t front ring which isn't enough range for me on steep long climbs. Which 28t rings would be a direct replacement and what's involved like shortening chains etc. Really appreciate your input.
    Sent from my SM-G925F using Tapatalk
    Reputation: LargeMan's Avatar
    May 2017
    Sram or WolfTooth make a DM (direct mount) 28T chainring for that crank and you would want a 3mm offset for Boost spacing. Sometimes you do not need to remove a link when going from a 30 to a 28, but I normally remove 1 link. Just need a 11 speed chain tool to push a pin out and re-use the quick link or replace it. Makes it a lot easier if you use a quick link tool to separate the chain. MLP - 1.2 and CT - 3.2 by Park Tool.
    Aug 2017
    Quote Originally Posted by LargeMan View Post
    That's brilliant mate thank you . So I'm looking for a direct mount chain ring with a 3mm 0ffset and it should be a straightswap with a link out...
    Aug 2017
    I've just discovered the oval chain ring now... seems better ?
  1. I want I want I want
    By Osco in forum Fat bikes
    Last Post: 11-15-2014, 08:00 PM
  2. #want want want!
    By chollaball in forum Arizona
    Last Post: 10-06-2012, 02:21 PM
  3. Replies: 9
    Last Post: 06-22-2012, 07:08 AM
  4. I don't want, I dont want, I don't want
    By Johnclimber in forum Fat bikes
    Last Post: 04-21-2012, 08:22 PM
  5. want a change for racing ralph on front
    By michaelo in forum 29er Bikes
    Last Post: 01-16-2011, 08:31 PM
Members who have read this thread: 9
