Results 1 to 5 of 5
    May 2012
    Hammerschmidt Crank Bolts...
    Good Day,
    Would anyone happen to know the part numbers for the Hammerschmidt Crank Bolts?
    My 8mm Bolt broke on the Drive side. I figured I would just replace both sides at once.
    Thanks,
    Roger
    May 2012
    Thanks for the link...
    But, once again, as was the case with a bunch of other Hammerschmidt parts pages, I do not see the crank arm bolts.
    Roger
    <100%
    Reputation: JackJr's Avatar
    Roger,
    I don't think the bolts are HS specific. They would be BB specific depending on whether you have the FR (M12?) or AM(M15?) version of the HS. Get the TV self-extracting bolt for your BB and I would guess you are good to go. That BikeParts link has a bunch of crank bolt options for Truvativ cranks. Otherwise, try your LBS.
  1. Swapping crank arms on Hammerschmidt
    By dynamicz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-07-2012, 10:13 PM
  2. Need help selecting crank bolts
    By chuck732 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-07-2011, 12:20 PM
  3. Crank bolts................
    By charliethetuna in forum General Discussion
    Last Post: 09-18-2011, 10:55 PM
  4. Replies: 12
    Last Post: 04-28-2011, 06:54 AM
  5. Hammerschmidt FR crank w/ Hammer AM Bottom Bracket???
    By E_braker in forum Downhill - Freeride
    Last Post: 04-15-2011, 09:25 PM
