Results 1 to 5 of 5
Thread: GXP BB issue
    Reputation: Hikers Only's Avatar
    Oct 2010
    GXP BB issue
    I have the GXP BB set up with a Noir crankset, and on the drive side there is a 1/4 inch gap between the BB and the inside edge of the crank. I have called SRAM and they said that it's not a problem. But, the issue I am having is the the spacer/washer on the drive side creeps its way out of the BB in to the space and is allowing all kinds of crud in to the BB.
    Just wondering if anyone is having the same problem as me? If yes what have you done to remedy it?
    29er
    gap is normal
    Oct 2010
    Quote Originally Posted by Dan GSR View Post
    gap is normal
    That is not the problem, it's the migrating spacer that is the problem.
    29er
    big glob of grease on the inside of the plastic washer should do the trick
    Hi Dan GSR. I am looking to purchase a photo from you..please contact me at 973-714-3892]. it is a NYC photo. Thanks so much!
    Lorraine
