Results 1 to 2 of 2
    Jul 2013
    Greasing SRAM Pressfit GXP bottom bracket bearings
    My previous bike had BB30, and greasing the bearings on that was simple: Remove the crank, remove the outer seals, remove the bearing seals, add grease, reassemble.
    Just purchased a new used bike that has Pressfit GXP, and not sure how to do it here. The drive side bearing looks very similar, and the bearing seal comes off just as easily as on BB30. However on the non-drive side the bearing seal looks very different, and does not come off easily. Do I just need to pull it harder, or is this not removable?
    On my bike a Superfly 100 the seals both come out on the GXP bearings.
  1. Replies: 9
    Last Post: 08-05-2013, 08:31 AM
  2. Which bottom bracket for pressfit?
    By bluesrider in forum SRAM
    Last Post: 07-30-2013, 09:59 AM
  3. Bottom bracket bearings getting dirty too quickly
    By dasaltek in forum Beginner's Corner
    Last Post: 06-18-2013, 07:47 PM
  4. bb30 bottom bracket pressed into a Pressfit 30 (PF30) frame
    By trail rida in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2013, 10:19 AM
  5. Need new Bottom Bracket / bearings..am lost
    By AXOP in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-23-2011, 06:34 AM
