    Giga X Pipe installation question
    I've got an 853 Jamis Dragon frame that I'm pulling the shimano crank out of and putting in a Truvative Giga Pipe BB and ISIS crankset. The frame shell is a 68mm and the spindle is 113. The Giga BB calls for a spacer on the drive side for 68mm shells, but in order to get it so seat properly in the shell, I need to use a spacer on both sides, which is consistent with SRAM's instructions on the web. Problem is, when I snug the cups to the BB shell, the spindle tightens up and has a huge amount of drag.
    What gives? Any install tips/tricks/advice? Is there a better/different placement for the spacers? 2 on the drive side does not work at all.
    thanks
    Reputation: SenorSerioso's Avatar
    Is the plastic sleeve seated properly in the shell? Try installing without that plastic sleeve and see if it's the issue.
    The Giga Pipe doesn't use a plastic sleeve - that's the GXP. The Giga is very similar to a Shimano UN series cartridge/sealed bottom bracket.
    Ended up buying a new Gga pipe with the correct drive side spacer and non drive side o'ring. It spins like butter now and all is good.
