Results 1 to 5 of 5
    Does Anyone know the BCD of the OEM Sram Specialized Stumpjumper crank?
    Thinking of going 1x10
    Below are my crankset specs
    CRANKSET
    Custom SRAM S-1250, 7050 alloy arms, 10-speed XC double, PF30 spindle, 15.5": 170mm, Others: 175mm
    CHAINRINGS
    38/24
    Jan 2013
    It should be 104mm and 64mm BCD.
    Thanks!!! Im on 1x10 now!!! woot woot!!!
    I'm doing the same thing with my Stumpjumper. Your crank was 2x10, correct? Did you need single speed bolts or bolt spacers? Or, did the original bolts suffice?
    Purulento
    I have the same crankset. Just take out the the 2 original chainrings and put the new one in place of the 38t chainring. No different bolts needed. You won't even need to shorten the chain if you're using 11-36 cassete and a x9 10s medium cage deraileur (im my case)...
  1. Replies: 63
    Last Post: 05-27-2015, 06:29 PM
  2. used Specialized pitch vs. used specialized stumpjumper
    By jbourne84 in forum General Discussion
    Last Post: 02-09-2013, 07:28 PM
  3. Replies: 0
    Last Post: 01-14-2013, 07:54 PM
  4. Compatible Chainring for Specialized Custom SRAM crank
    By ckit77 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-13-2012, 12:39 AM
  5. should i spend the extra $100 and get the xt deore 2x10 crank over the sram x7 crank
    By crclawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2012, 11:27 AM
