Results 1 to 2 of 2
    Mar 2013
    Converting a Stylo from a 3x10 to a 2x10
    Hi everyone,
    I'm pretty new to the MTB game and I wondering if anyone could help me out.
    I have a Niner RIP9 that currently has TruVativ Stylo GXP Crank that I would like to change to a 2x10 to help out with my chain suck issues (that is common with RIPs).
    With that said I'm understand that I can get the top gear taken off and get a bash guard put on as an "easy" conversion? I do understand this isn't the best way to fix my issue and that getting a true 2x10 would be the better choice however I currently do not have that in my budget.
    So I have a few questions when it comes to converting my stylo to a 2x10.
    1) Bash guards, overall I'm a little lost. I see there are different types is that just for appearance? I also notice that some makers have sizes however others do not. Can anyone point in the right direction on which bash guard I should get?
    2) Do I need/have to change my detrailer and/or shifters? Or is the current one okay?
    Just incase it helps here is a list of my drivetrain:
    TruVativ Stylo GXP Cranks and Chainrings
    SRAM X9 Rear Deraulier
    Shimano XT front
    SRAM X9 shifters
    Thanks for your help.
    Vince
    My guess is you get chain suck because of your current ring configuration (the position of the rings). It's probably worse when on/shifting to the two smallest rings, right?
    If so, it won't help for you to exchange the biggest chain ring with a bash guard.
    I don't know anything about the particular problems with the bike, but it sounds like you'd want a dedicated 2 x 10 crankset. For instance X9. They're quite cheap.
  1. Converting XT M780 3x10 to 2x10 - Which 36T chainring?
    By Hokidachi in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-27-2013, 12:42 PM
  2. Converting SRAM 3X10 to 2X10
    By Merost in forum SRAM
    Last Post: 09-18-2012, 11:19 AM
  3. Some quick questions converting my bike from 3x10 to 2x10
    By nord1899 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-08-2012, 06:54 AM
  4. Converting giant anthem 3x10 to 2x10...possible?
    By slimphatty in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-21-2011, 05:52 PM
  5. Replies: 0
    Last Post: 11-18-2011, 06:50 PM
