Results 1 to 2 of 2
    Reputation: ihaveagibsonsg's Avatar
    Convert Lyrik Solo air R to Adjustable
    Is it possible to convert the standard Lyrik Solo air R so I can adjust the travel? I just bought a specialized enduro comp and I'd like to make it a little more climbing friendly for some nasty grinds around here.
    Stand back
    Reputation: dbabuser's Avatar
    Yeah, you just need to pick up the new spring side internals. You can either go with u-turn coil, or 2 step/ dual position air. Dual position air is new for this year, looks to be a bit simpler and maybe lighter than the 2 step. I am in the same situation as you - have a new Enduro comp frame to build up, and found a Lyrik 170 coil. I picked up a 2 step air spring assembly for it, and am hoping to get it swapped over this weekend. I'm still waiting on new wheels before I can finish the build, anyway, so no huge hurry, unfortunately...
    Golden Bike Park
    Golden Connector Trails need your support!
