Results 1 to 8 of 8
    Broken Maxle 12mm rear axle
    I am riding Reign X (2011) with Novatec 4in1 hub and Maxle 12mm rear axle. All was fine until last week, when the axle was broken while landing a jump and caused me a bad crash. It was broken at the begining of the thread. Happened to anyone else?
    Attached Thumbnails Attached Thumbnails Broken Maxle 12mm rear axle-img_0011_2_1.jpg
    I've been running Maxles on my two heaviest-use bikes, 135mm and 150mm flavor, for over three years... never had an issue.
    I'm now knocking on wood.
    Sorry for your luck!
    Weapon of Choice
    Reputation: Iceman69's Avatar
    Same thing happened to me, same break location as well. I crashed at slow speed going up a steep rock, landed sideways just enough to hit the maxle on its side. I had been doing alot of jumps to flat prior to this happening so I believe it was just a matter of time before failure. Prior to this I had never tightened the maxle using the inside lever hex bolt; my guess is there was a slight amount of play and this caused the failure.
    Super Unknown
    Te mortuo heres tibi sim?
    Here's what you do.
    Get one of these:
    Hadley 12mm Bolt for 150mm spacing at Balle Racing
    and one of these:
    12 mm X 1.75 X 1-1/2" O.D. Metric Die: Amazon.com: Industrial & Scientific
    Cut the threaded end off, re-thread with the die, and Bob's your uncle.
    Straight and solid, works very well - have never had it loosen up.
    I've got two I made for a prior frame- made a spare, just in case. Then of course discovered they worked beautifully on the rear end of my Reign-X Unless Giant or SRAM has changed the thread size and pitch, the 12mm x 1.75 is what you want.
    Good job!
    Thanks! I followed your instructions and it looks good! Hope it will hold.
    BTW, do you use it with the spacer or without?
    Quote Originally Posted by anavot View Post
    If you've got enough length to have enough threads engaged and run the spacer, sure. If not, don't sweat it. Been using mine without the spacer for quite a while now, and have not had any trouble.
    some know me as mongo
    USE THE SPACER! if not you risk spreading your dropout!
    3000 mile goal for 2018
    3402.7 miles ridden in 2017
    3028.4 miles ridden in 2016
    Quote Originally Posted by sir_crackien View Post
    How? I can't imagine doing that with it on a captured thru-axled dropout like his frame has. I'd think you'd screw up the threads or the bolt head way before you'd screw up the frame.
    And for what it's worth, I crank mine damn tight - no issues whatsoever. The large bolt head/flange sits flush against the flat part of the thru-axle dropout bit, so I really don't see how it could cause that.
    In fact, mine has been used on two different frames like this, as a replacement for the Maxle. No problems.
    Now, if you were using the 10mm version on a regular QR dropout without the spacer, that would be dumb, but that isn't what we're talking about here.
  1. basic Qs on rear Maxle Lite 142mm x 12mm
    By PiroChu in forum Wheels and Tires
    Last Post: 05-25-2012, 11:19 AM
  2. Replies: 34
    Last Post: 03-17-2012, 10:05 AM
  3. Maxle rear axle has been broken!
    By OLEAJE in forum Ibis
    Last Post: 11-01-2011, 10:25 PM
  4. Broken Rear Maxle Axle
    By card in forum Marin
    Last Post: 05-02-2011, 08:19 PM
  5. Beware the rear 12mm Maxle Lite
    By thepimpmessiah in forum Nicolai
    Last Post: 03-27-2011, 04:39 AM
