Results 1 to 5 of 5
    Reputation: SenorSerioso's Avatar
    ISCG tabs?
    Bash guard for Sram 2x10
    Hoping for some help. I have a Salsa Horsethief with a Sram S1000 2x10 crankset (36t/22t).
    Very similar to this: SRAM S1400 2X10 | SRAM
    I need a bash for it. Is there anything I need to consider with Sram compatibility? I'm guessing I can just throw it over the big ring and ad some longer bolts.
    I am also wondering what size I should get. Is a 36t bash designed to go over a 36t ring, or do I need to up it to a 38t or 40t?
    I was thinking about a Truvativ Stylo bash or the Race face Light bash.
    Thanks in advance!
    That frame does have the ISCG tabs, you could go with a skid plate type bash guard instead. Something like the MRP XCG would work. If you do find a bashring that works, post it up.
    Yeah, it does have ISCG tabs on the frame. I'm not sure if I want to throw on a big clunky guard and chain guide. What are the odds of bending the mounts/frame? I guess I'm not super familiar with ISCG mounts and devices.
    I'm guessing a standard bash guard will work? Am I correct in thinking this? Truvativ Stylo bash looks like a match.
    Did you ever find a solution?
