Results 1 to 2 of 2
    2013 Reba Solo Air concerns. - 100mm to 80mm
    Hi - Im currently using a 100mm rockshox reba solo air.. If I get my fork converted to 80mm or 90mm. will the drop of the front end be exactly like the reduction of the fork travel? Cause I really need just 10mm bit more lower Im fine..
    Noticed that the rockshox reba.. has a longer axle to crown than lets say an epicon .. thats why Im currently debating if I should convert.
    Sad thing with the new Rebas is that a spring assembly is needed and not a travel spacer anymore.I still have my old travel spacers and thought I could use them..But I'm willing to spend if it will give me the fit I like.
    Any advice? Leads where I can also get a Rockshox 2013 Reba Spring Internals aside from Jensen?
    bike tester
    Reputation: syl3's Avatar
    just run more sag
  1. Replies: 55
    Last Post: 04-10-2015, 01:57 PM
  2. Reba 80mm to 100mm Easy??
    By tomv1975 in forum 29er Bikes
    Last Post: 01-11-2014, 07:45 PM
  3. Replies: 1
    Last Post: 07-06-2011, 04:14 PM
  4. Replies: 23
    Last Post: 07-05-2011, 07:44 PM
  5. 80mm to 100mm for 2005 Reba 29" fork?
    By gk02 in forum Shocks and Suspension
    Last Post: 05-22-2011, 01:31 PM
