Results 1 to 8 of 8
    Oct 2013
    2013 Lyrik Upgrade
    I have a 2013 Trek Slash with the Lyrik R. Ive been researching on how to upgrade it but cant find any solid facts.Does anybody have any input on upgrading to the Mission Control Damper and Rebound?A few hundred dollars is cheaper than a new fork.thanks
    Te mortuo heres tibi sim?
    Compression damper, regular or DH version same price.https://www.universalcycles.com/shop...&category=5671
    Rebound setup.
    Pike air side topcap and tokens will fit and allow you to tweak the air volume like you can on the Pike! Have done it to my Lyrik and works wonders.
    Can also ditch the qr axle and use a Boxxer Maxle. Been doing so a few years now and prefer it quite a bit.
    Shop around, may find better pricing.
    Supposedly Rock Shox will have a Charger compression and rebound drop in upgrade kit to pop into older Lyriks, but I've not seen it for sale yet.
    Edit: found it! Just ordered one up for my own fork. Sweet!
    RockShox Lyrik 26" Charger Damper Upgrade Kit | Chain Reaction Cycles
    Wanna' buy a slightly used MiCo DH damper and rebound setup?
    Charger dropping in!
    Will get a ride in today and see how it feels!
    Any updates on the charger upgrade? I have an old 170 Lyrik lying around that Im trying to figure out what to do with.
    Feels just like the one in the Pike on my other bike. No issues.
    I'd say it's a worthwhile upgrade to an older Lyrik, especially if the chassis is still in good shape. You get new fork feel, for way less money. Do the topcap/tokens too - just gives you more tuning options, and is a cheap and easy bit to do.
    Reputation: calbert04's Avatar
    Feb 2010
    When you performed the Charger Upgrade, did you remove the bottom cap from the old rebound damper?
    Quote Originally Posted by calbert04 View Post
    I'm not sure what part you mean. The seal head?
    You're basically going to pull all the damper side guts out. Comp and rebound.
    Charger damper goes in as one unit to replace everything.
    Feb 2010
    Yeah, the seal head from the MiCo damper, I originally left mine in then took it out hater seeing your post. Pretty sure it doesn't matter much either way.
  1. ROCKSHOX LYRIK RC SOLO AIR upgrade
    By gwayms in forum Shocks and Suspension
    Last Post: 02-24-2014, 01:28 PM
  2. 2013 Lyrik
    By Cycle64 in forum Shocks and Suspension
    Last Post: 07-22-2013, 12:37 PM
  3. RS Lyrik 2013
    By raph11 in forum Shocks and Suspension
    Last Post: 04-11-2013, 02:59 PM
  4. Need help with possible stiction on 2013 RS Lyrik
    By Laterilus in forum Shocks and Suspension
    Last Post: 01-28-2013, 02:45 AM
  5. spring upgrade for RS Lyrik
    By ehigh in forum Shocks and Suspension
    Last Post: 10-30-2011, 04:29 PM
