Results 1 to 7 of 7
    10-36 Cassette XX1 without 42 ring
    Hi all,
    considering these many different drivetrain options I wonder if a xx1 (or x01) cassette can be mounted without the 42 ring?
    I just realized that a 10-36 cassette with a 32/24 front rings would be my dream choice. Probably the little shift in the chain line would be acceptable too.
    Any xx1 owners who can comment on this?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by mansy View Post
    Hi all,
    No. All of the drive splines are on the 42t cog.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    Thanks...!
    Aug 2010
    Mansy, if you are not committed to XX1 or X01, you could achieve the same gear range by combining a 24/38 or 22/36 crankset with a 10-speed 11-36 cassette.
    Quote Originally Posted by WillTheGreat View Post
    Well I do know that. In my opinion it is however not only about the overall bandwidth of the drivetrain but also about staying as much as possible on one front ring without shifting in the front.
    In my experience I can really do 90% of the ride with the 32 - 11/36 combo. I would love to have what I currently achieve with 42/13 and don't want to loose the 24/36.
    Having a 10/36 cassette will do all what I mentioned before.
    Additionally I have my second thoughts about having a 14 tooth difference between the 2 front rings. You really need to shift lots of gears in the back to compensate this.
    However I do agree that 36/24 in the front would come very close.
    what about mounting a 11-36 on an XD body and adding a 10 teeth cog. Is this possible? That would actually be even better
    Dec 1998
    There are only two cassettes that fit the XD driver. Both are SRAM 10-42 11-speed.
    mtbtires.com
  1. XX Cassette...36t Ring
    By DavidR1 in forum SRAM
    Last Post: 06-22-2014, 10:08 AM
  2. XX1 cassette/shifter/derailleur with NON-XX1 crank/ring?
    By Walt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-24-2012, 06:53 AM
  3. chain skips 2nd largest cassette ring
    By rakerdeal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-18-2012, 11:42 PM
  4. Sram Short Rear cage with 11-36 cassette and 30T ring
    By jazzanova in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-26-2012, 07:45 PM
  5. Replies: 30
    Last Post: 06-29-2011, 06:10 AM
Members who have read this thread: 7
