Results 1 to 8 of 8
    = dirt torpedo =
    your 2010/2009 SX-Trail spring rate?
    hey guys
    just built up a 2010 SX-Trail, and i'm super stoked on the bike! However, the stock 600 spring that comes on the Large is a bit too soft for my weight. I'm getting about 40-45% sag with it.
    I am around 205 all dressed up to ride.
    If there are any similar sized SX-Trail riders out there, what spring rate are you guys running to get perfect sag?
    Your input is much appreciated
    Reputation: terf!'s Avatar
    What size did you end up going with? Mine came with a 550 spring and I'm also getting about 40% sag (I weigh 180 with gear). Not sure if I should go with a 600 or 650 weight.
    Anyone else?
    Nov 2008
    I have a 2009 SXT and I am running a 650lb spring, also went harder on the front coil as well. I weigh about 95kgs, with gear. Sag is about 30%. Use mine mostly for trail riding and light freeride stuff.
    Rob.
    troubled economist
    Reputation: toowacky's Avatar
    May 2005
    650# coil, 200 lbs rider (with gear), no ProPedal (comp), 130 in boost.
    More here:
    2009 SX Trail/ DHX 4.0 coil setup
    dig...
    Reputation: tshred's Avatar
    Dec 2004
    09 SXT
    I'm about 190# with gear...
    600# DSP Ti Spring, at 160 psi in boost
    30ish% sag
    I roll the propedal all the way stiff on the way up, the opposite on the way down.
    2010 SX Trail med
    Fox RC4, running a 550 spring, 27%ish sag.
    I am 160lbs with gear.
    Quote Originally Posted by tshred
    09 SXT
    30ish% sag
    is your sx the copper one?
    where did you get your ti spring?
    Dec 2004
    Ive got a black frame. The ti spring is from DSP I think...my bike is at home, across the country.
