• 12-26-2012
    5power
    Xx1 spider for s work crank
    Anyone have any info on this? I currently have s work cranks and would like
    Xx1 drivetrain but keep the s work crank.
  • 12-26-2012
    erichwic
    Good luck.
  • 12-26-2012
    bpd131
    I called Specialized and asked this question. The response was basically that they anticipate having them available in the Spring of 2013.
  • 12-26-2012
    jut8
    I heard early feb they will be coming into stock, they have a part number for them: S131400004
    looks like it will come with a 34t chainring.
  • 12-26-2012
    bpd131
    Yeah they told me March, but didn't want to commit to it so he left it at spring. I like Jut8 response better!!!!
  • 12-27-2012
    chillie
    I'm also keen but i don't think it is going to be as simple as that.Looking at the specialized bikes that have come with XX1 they have a huge spacer on the driveside of the crank that i havn't seen before.I don't think it is going to be simply a spider changeout.There might be some spacers in the BB that are also needed.As we all know the specialized crank is not as straight forward as other cranks out there.
  • 12-27-2012
    bpd131
    It is the same as installing with any other spider.The original intent for these was for the 84.5mm OSBB, which is straight forward. When used with a PF30 BB (73mm wide) there are spacers needed, but that also lets you adjust chain line too. You can also creatively run these on a 68mm BSA, which is what I was doing for 2X10 and will be using them on for 1X11.
  • 12-27-2012
    MarcoL
    use the carbon Ti spiderless chainring
  • 12-31-2012
    ruri
    I run these cranks on a 68mm bb. This spider will be awe fully expensive when it comes out
  • 01-03-2013
    dypeterc
    running a renthal S4 ring (http://www.renthalcycling.com/File/product_sr4_120.aspx) on my XX spider for 1x10 setup. the ring is offset by a mill or two for better chainline. not sure if you need a guide w/ a clutched rear der but i would for added peace of mind.
    Photo by dypeterc • Instagram
  • 02-28-2013
    JMCCRNA
    Picked up this spider through the local BS. It was $66. No too bad, but not the cheapest. Still waiting for specialized to confirm what spacers are needed.
  • 02-28-2013
    CarManDSL
    Got my XX1 spider for SW cranks 3rd week of January. Laser dated Dec 24/12. Haven't installed yet.
    Eyeballing the chainline with the XX1 spider places the XX1 ring at the same position as the big ring on my 2011 SW Epic 29. This is smack in the middle of the cassette. Can't see a reason for a spacer. This spacer may be an illusion, as the inside granny ring obscures the spacers between crank and BB. The XX1 spider is narrower, thus exposing the spacers.
  • 03-07-2013
    xavier lord
    Any pictures with weith available?
  • 03-17-2013
    Green Giant
    extra spider and tool if needed
    Attachment 781607
    I have one new in the packaging along with a QUARQ lockring tool (needed to remove the lock ring on the cranks and much cheaper than the specialized tools).
    Drop me a line if you want them.
  • 03-17-2013
    JMCCRNA
    I installed my s works cranks and XX1 spider using the standard bottom bracket spacers used for the double.
    JMC
  • 03-17-2013
    CarManDSL
    I finally installed the XX1 group set on my 2011 SW Epic. Had my LBS change the spider out as they had the special tool.
    No extra spacers required and the XX1 spider and 32t ring lines the chain up with the middle gear on the cassette as I had thought it should.
    As well, when I mounted the Epic onto my Cyclops trainer, the wheel I use which has a slick tire and a 142+ hub with 10spd 1070 cassette, all the important gears worked fine, (hardest 5 gears) with the XX1 der and chain. No der adjustments required.
  • 03-17-2013
    dypeterc
    can you post a photo of your drive-side spacer arrangement
    JMC
  • 04-29-2013
    chillie
    Can you guys please give an indication of what you are paying for the spider.Here in South Africa it is costing over R2000 which is over $200 without any blades from Specialized.A bit of a rip if you ask me.Add to that the cost of the crank,BB and blade and you have one hefty price to pay.
  • 04-29-2013
    CarManDSL
    XX1 spider for SW cranks, retail in US is about $95.00. In Canada it is similar to your pricing, so you are not the only country that gets bit hard on pricing.
    You may be better off getting the whole XX1 crank which comes with spider and 32t ring from Chain Reaction or other online store, then sell your SW set-up.
  • 05-01-2013
    a.k.
    hi
    i'm looking for lockring tool. where can i buy it?
    thanks
  • 05-07-2013
    AKRC78
    I'm thinking of running the s-works with xx1 spider on my Air 9 RDO but I'm not sure about the chainring offset. The xx1 crank has a max 32t due to chain-stay interference. So I'm wondering does the s-works offset the chainring the same or will it be farther out? When I eyeball my current bb30 sram 2x10 the chainrings split the cassette into thirds evenly.
    Any advice other than get a new frame:madman: would help. I'd like to be able to run the 34t
  • 05-07-2013
    CarManDSL
    Love the stylized SW cranks on my SW Epic and wanted the same for my Air9 RDO build.
    In the end I got XX1 cranks and did a 3 bike mix-up of drive components. XX1 cranks are about 20 grams lighter and much less cost. Also wanted the SW in accent red to match and was not available in Jan.
    The Air9 RDO has XX1 cranks with a SRAM 104 bcd spider from the Specialized SJ EVO 29er and a Race Face 34t ring. Had a 36t SRAM ring on as well and with either ring, chain line is biased to out side of cassette, centered on the 5th gear from outside on a 10 speed cassette.
    Space between ring and chain stay seems close, but hasn't been an issue. Seems the 36t had a slight curve to the outside and space to chain stay is about the same on either ring.
    I'm running the 32t XX1 ring from the XX1 cranks and SW XX1 spider on the SW Epic.
    In the end from the 2x10 set-up with 38/24t rings, I loose only one gear at the top and one at the bottom. Gears I hardly used anyways. You should be fine with the 32t.
    Sorry, can't answer your question, whether or not a SW crank with XX1 spider and XX1 32t ring will fit the same as a complete XX1 crank set-up, but hope this info helps is some way. Had everything disassembled at one point and could have test fit either way, but didn't think of that possibility.
    I would assume XX1 and SW cranks have the same spider offset as that would be the standard that SRAM would have designed. Call Niner and speak with Ralph.
  • 05-12-2013
    AKRC78
    Thanks for the info. I think i'm going to stick with the 2x10 for the beginning of the season then maybe get a 104 bcd spider to run 1x10. But damn those S-work cranks look good! 1x11 will go on my next bike.
  • 08-06-2013
    garinfrost
    I need an XX1 spider for the s-works crank. Do you have one?
    Attachment 781607
  • 08-07-2013
    gnriden
    Lightning Carbon Cranks
    This may fit. The 2x and 3x are interchanable between S-Works cranks and Lightning cranks.
  • 08-23-2013
    erichwic
    Bti-USA.com has the xx1 spider for the sw crank. I believe qbp does as well.
  • 09-07-2013
    Pete N
    Is this Sram part number( 11.6118.004.000) the same product as the Specialized spider.
    I'm hoping that it is but each company has their own part number? If so the Sram part is much cheaper.
    I want to fit XX1 on my 2013 S Works .
  • 09-07-2013
    CarManDSL
    Mine came with the following numbers from Specialized
    S131400004 01/15/2013 339749 XX1 SPIDER
    $95.00 retail in US.
    Could not see any numbers on the part as it is mounted. The parts numbers are under the mounting nut.
  • 09-08-2013
    renoirbud
    I bought;
    Truvativ Sram XX1 Spider for Specialized Cranksets
    76mm BCD, Gray
    Part No.: 11.6118.004.000
    Fits Specialized Cranksets
    I also boughth the rediculously priced S-works tool set for carbon cranks.
    The XO spider was easy to remove the XX1 spider was easy to install, It all looks vey nice. I put this on my 2012 S-Works Stumpjumper and am happy I spent the money (I have another bike that has the S-Works cranks, so maybe I get to use that $300 tool kit again, LOL)
    It is cheaper to have a shop do the swap or just by the XX1 cranks.
  • 09-09-2013
    Pete N
    Thanks, just what I wanted to hear. Spider and chainring ordered.
    Specialized wanted 120 for the spider in the UK. Managed to source the spider for 48 and chainring for 50.
  • 11-16-2013
    avicmar
    hi everybody,
    Do you know if this SRAM spider will fit the X01 crank of a specialized enduro expert 29?
    I wanted to install a 28T chainring and in a X01 you can only install a 30T as a minimum. There is a brand, North Shore Billet, that makes a suitable one to fit a 28T as in XX1. If original SRAM spare part fit I would buy it, otherwise I would buy NSB one.
    thank you and Best regards from Spain
  • 11-16-2013
    sevenpedaler
    Wolf Tooth
    I just bought a Wolf Tooth in 34t that went right on the Sworks crankset. I'm running single speed, but they were the best option if you want a Spec crank. Nice ring! Made in USA. They have a 32t available and I heard maybe other sizes in the pipeline. Good Company right here in MN.
