    XX1 chainset on Epic 2012
    been running a 36T Bling Ring on a SRAM GXP crank with PF30 to BSA adaptors on my Epic all winter, no problems with clearance,
    for the summer I have switch back to a PF30 BB and using BB30 SRAM cranks, problems with clearance on the Bling Ring,
    Is anyone using a XX1 with 34T on a 2012 Epic Carbon Comp (alloy rear triangle)? Which Q-factor? Does 156 have enough clearance?
    Also do you run a chain device with the XX1?
    I'll give you my situation even though it isn't the same.
    32T XX1 crank/ring on a 2013 Carbon Comp. I went with 168Q because I had read that Specialized mountain bikes are not set up for 156Q. SPECIALIZED | Q Factor needed for 2011 Epic Expert EVO...
    I figured I could go wider without any physio problems, but I couldn't go narrower due to it not fitting on the bike. Fat bike Q factors are like 200+ I think and I haven't seen anyone complain about the Q factor on them yet.
    I am using an XT RD w/ clutch in a 1x10 setup and no chain guard and I dropped a chain once in the 250+ miles since I have been running it. It was when I cased my rear wheel on a log while trying to bunny hop it and I think spinning the cranks while shifting at the same time. It dropped off on the outside.
    Reputation: OrbeaAbsalon's Avatar
    I'm running a XX1 36t with a 156q on a 2011 Epic Expert carbon 29. It's close and the max you could go.
    Quote Originally Posted by OrbeaAbsalon View Post
    No modifications to the BB for this? Wonder why Specialized says (external link above) they require q166?
  1. Replies: 2
    Last Post: 03-30-2013, 08:54 PM
  2. Replies: 5
    Last Post: 07-14-2012, 05:08 PM
  3. 2012 S-Works Epic 29er build or 2012 Expert Epic 29er?
    By crimecrusher in forum Specialized
    Last Post: 12-27-2011, 11:04 AM
  4. 2010 S-Works Epic (26) to 2012 Epic Expert 29er
    By MrEconomics in forum Specialized
    Last Post: 11-21-2011, 11:00 AM
  5. Replies: 13
    Last Post: 09-20-2011, 11:51 AM
