Results 1 to 25 of 25
    XX1 142+ free hub body
    Anyone got an extra lying around?
    Is the only difference between the 142 and 142+ the endcap?
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    For what hub?
    I have a set of roval traverse 2014 wheels from an endure which I'm changing to 10spd, so the xx1 free hub is available.
    Quote Originally Posted by irishpitbull View Post
    DT 240 for the Carbon SL's.
    So annoying specialized wont have any freehubs till Feb. This might be the last straw...
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    Broken but on the mend
    Reputation: mzorich's Avatar
    Mar 2011
    i need one as well if anyone has one
    Why do you all think you need one from Spesh? Any DT freehub body will work. The difference is in the end caps and the spacing between flanges.
    What am I missing?
    Mar 2011
    the end cap is 2mm wider for the 142+ spacing which you can only get from them
    Quote Originally Posted by mzorich View Post
    Do you have a specialized part number for this? I ordered some carbon SL wheels (not in yet) and told the bike shop I needed an xx1 freehub. They ordered the freehub from one of their distributors and I was told this would work on my frame. I even called specialized and asked if I needed anything specific from them regarding the xx1 freehub and 142+ frames but they said NO. Anyone know for a fact?
    Reputation: CarManDSL's Avatar
    You need the Specialized DT Swiss version. It is different from the DT Swiss version as found on their site for the 240 hub.
    This is the Specialized part number for 142+ 11 spd free hub body. You also get a different end cap.
    17 990 Element BC Ed - 25.5 lb burly
    15 Enduro Expert 29, SW build - 27.6
    14 SW Epic WC - 21.8
    12 Niner Air9RDO -16.4
    Thanks for the pic. I also posted this question on the specialized website (Masterlink FAQ). This is what they said (my question and their response below)
    My question: I purchased a 2014 s-works stumpjumper HT frame which has the 142+ dropouts. I have ordered a set of roval control sl 142+ wheels from my dealer. I told them that I needed an xx1 freehub so they ordered that from a distributor. I did read on a forum that I need a specific 142+ endcap that comes directly from specialized to use with that xx1 freehub. Is this true? If so, do you have a part number for this part so my dealer can order. I discussed this with my dealer and they didnt think this was true. Please help!
    The Response: You can order that endcap kit under part number S132100005.
    Ok - I posted before: the end caps are absolutely different. I have validated this myself as I have DT 240 and a Roval 142+ wheel. But for the life of me I can not see the difference between the free hub body on the Roval and the DT. They look identical.
    Quote Originally Posted by onobed View Post
    There seems to be a lot of confusion about this but it is really fairly simple.
    142+ hubs have the driveside of the hub (and consequently the freehub body) positioned 2mm further outboard than a traditional 142 hub. Since the freehub is moved out 2mm, the driveside endcap is 2mm shorter. This allows the bracing angle of the 142+ spokes to be slightly stronger than a normal hub. In order to do this there needs to be clearance for the hub on the driveside dropout, which is what specialized means when they say 142+ frame. All of the new specialized 142 frames will work fine with a normal 142 hub from any manufacturer. Also some frames from other manufacturers will fit 142+ hubs even though they were not intentionally designed to do so.
    Moving on... If you want to convert a star-ratchet equipped 142+ Roval hub from 10spd to xx1 you will need a new DT freehub body. You can get a 142+ XX1 freehub body from specialized and it will come with the correct endcap. Often this part is out of stock but the freehub can also be sourced from DT. If you get it from DT you will still need a 142+ endcap which DT will probably not have. You can reuse the 142+ driveside endcap from your 10spd freehub; however, you will need to use a lathe (or a grinder will work) to machine away some of the endcape bearing shield. You can see in the attached picture that the XD endcap has a smaller diameter bearing shield than the normal 10 spd endcap.
    If your hub is a 142 (NOT 142+) Roval, the normal DT XX1 freehub and endcap are compatible without modification.
    Mar 2005
    Quote Originally Posted by erlau View Post
Name:	Screen Shot 2014-01-17 at 6.36.49 PM.jpg
    Doesn't this also mean you could just file off 2 mm of endcap on the DT part and get the same result. A lathe would of course be better, but I'd think if you carefully marked it out first you could take off 2mm very evenly with a flat file. Just a thought
    Quote Originally Posted by phatfreeheeler View Post
    Yes, that should work also. Just make sure the surface is close to flat&square when you are done so that the hub clamps into the dropouts nicely.
    I still have the xx1 freehub and endcap taken off a set of 2014 rovals from an enduro expert.
    I put the rovals on my sworks 2013 which i sold 10speed so this is basically new.
    I'm based in the uk if anyone is interested.
    sld
    sld is offline
    Jan 2014
    waldo1: I'm interested for endcap, can you write me ? Thank you
    142+ wheel
    I have an extra rear wheel in 142+ I'd take $450 and shipping for if anyone's interested. It's in excellent condition. 2012 model.
    @Sld i sold the freehub and endcap now sorry.
    Jun 2010
    XD 142+ End Cap PN
    I just went thru this mess converting my Epic to XX1 and the PN on the bag for the endcap I got is S145900003, if that helps. My local Spec dealers were totally unaware of the need for a special endcap with this setup. I originally put a standard DT Swiss XD-compatible end cap on and it's, of course, too wide. But, you can get the wheel on the frame without much trouble. The biggest problem I see with that combo is the large gap left between the small cog and the chainstay. During a recent race, the rear der picked up a small branch from the trail and caused my chain to come off track. The chain settled into this extra large gap created by the non-142+ spacer and wedged in tight. I had to stop and yank pretty hard to get it loose before continuing. So, even though the wider spacer runs just fine, it could cause you this little jamming issue if the chain gets knocked off the small cog. Good luck!
    Reputation: c-wal's Avatar
    I've got an 142+ endcap which was used for a short time with a new xd driver if anyone is in need. These are difficult to get outside of the dealer (I had to pay retail...).
    Oct 2012
    Quote Originally Posted by c-wal View Post
    I'm interested. Can you PM me the details?
    I have a full brand new XD Driver XX1 with endcaps for 142+ Roval SL wheels. I thought I would need it when I bought my new Roval SL's but it already came with it
    PM me with an offer and I will send you pics of the brand new part.
    PM sent gigabyte772.
    Feb 2007
    Anybody have an extra 142+ 10 speed endcap? Please PM if you've like to sell it to me.
    Guys, I need help figuring hub spacing.
    I am about to buy a Spesh Roval carbon wheelset that comes with a 142+ rear hub/XD driver. I want to use this wheelset on a Turner Cyclosys which takes a 142X12 rear hub (Cyclosys v1.0 ? Turner Bikes). I also want a Shimano/Sram cassette body. Any idea which parts to buy?
    Thank you.
    F
    Reputation: phlegm's Avatar
    Are you buying new? If so, you have the option to buy "regular" 142 Rovals, which will work with any bike as-is. I've heard, however, that even 142+ can be squeezed into regular 142 frames, but that's not ideal IMO.
    However, officially, 142+ wheels (hubs) are only meant for Specialized-specific 142+ frames.
  1. Identify this Free Hub Body!
    By NC-Biker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-03-2013, 06:50 AM
  2. Free Hub body replacement?
    By jacksonj51 in forum Wheels and Tires
    Last Post: 03-22-2013, 10:51 PM
  3. Free Hub Body - Noisy!
    By Stumpjumper61 in forum 29er Components
    Last Post: 08-26-2012, 08:19 PM
  4. Free hub body
    By giantdirttrail in forum Wheels and Tires
    Last Post: 02-15-2011, 09:05 PM
  5. Free hub body
    By giantdirttrail in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2011, 03:59 PM
Members who have read this thread: 8
