Results 1 to 7 of 7
    Jan 2009
    XT Brake Upgrade - 13' Stumpy FSR 29 Comp
    I have finally had enough of the vibrations and sounds from the Avid's on my stock 13' Stumpy FSR 29'r Comp. I got a great deal on a set of 14' Shimano XT Ice Tech brakes and Ice Tech 180mm rear / 203mm front rotors. They are currently en route and I just realized I did not order adaptors .... is there any chance that the stock Avid adaptors for the calipers will work, or do I need to order Shimano specific adaptors?
    Thanks in advance for your advice!
    Mar 2011
    I did the same up grade and the stock Avid adaptors worked fine. Well worth doing.
    Jan 2009
    Quote Originally Posted by MURRAY NZ View Post
    This is good to hear! I put up with the Avid's on my 09' Stumpy until I got this 13' and then the 13' with Avid's started giving me grief ...... enough! Fingers crossed on the XTs!
    Jan 2009
    Did you new XT's play nice with the SRAM shifters?
    West Chester, PA
    There's no matchmaker option, but they play fine. Just make sure the body of the shifters isn't pressed up against the bottom of the brake lever pivot. If it is, the brake lever might not return quickly.
    Jan 2009
    Quote Originally Posted by 92gli View Post
    I just remembered seeing these in doing my research ..... hoping the 14' XT's will work with these and my 13' SRAM shifters
    Problem Solvers
    Jan 2009
    .... and then read in the instructions I need 12' or earlier XT's, boo.
  1. brake issues- 2014 stumpy comp EVO
    By Kabob King in forum Specialized
    Last Post: 12-03-2013, 11:05 PM
  2. Replies: 11
    Last Post: 12-18-2012, 06:45 AM
  3. Replies: 16
    Last Post: 10-07-2012, 08:46 AM
  4. 2012 Stumpy FSR COMP EVO vs 2013 Stumpy FSR COMP EVO?
    By RacinJason11 in forum Specialized
    Last Post: 09-03-2012, 04:51 PM
  5. Replies: 0
    Last Post: 07-04-2011, 02:12 PM
