Results 1 to 20 of 20
    wow, my stump weighs in at.....
    .......25.8 lbs. its a comp. really its all stock, except I have a geax beaumount front as well as mini pump, and a seat pack w/ tools and a tube. i was actually surprised. post up your wieghts...
    Reputation: jpc111's Avatar
    what size is your bike?
    My medium Expert Stumpy weights 28.5. Is has a XT cassette, Thompson seat post and, Echo wireless computer and carbon Specialized bar ends.
    2018 Trek Fuel EX 9.8 27.5 plus
    2012 Trek Madone 4.7
    its the 19 inch (large?).
    It's not that I don't believe your results, but I wonder how accurate your scale is?
    I weighed mine at work on a scale that is calibrated at least once a year.
    well if it makes you feel anybetter, the chain was off. lol
    Reputation: nachomc's Avatar
    hmmmmmm
    :wq
    is this a hardtail?
    Reputation: onegymrat's Avatar
    My LBS weighed my Stumpy HT at 25.9 lbs.
    Mar 2006
    Quote Originally Posted by typsu32
    you were surprised because you were wrong.
    that bike weighs 27+ unless its a small, then its ~26, but you're grasping with that claim.
    Never ever ever ever ever ever again on the internet call something "stock" that is not stock, its posts like this that confuse people.
    the words "stock" and "except" should never never ever ever never ever be in the same sentence.
    ...really its all stock, except....as well as.....and a....
    come on
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    My very un-stock 06 Stumpy FSR weighed in at 26.3 lbs before I switched to lighter tires and tubes.
    Oh yeah, it's a medium.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    I Wanna Be Sedated
    Reputation: Jouko's Avatar
    Mar 2006
    My 2007 Expert with XT cassette, RaceFace Next SL seatpost, SLR saddle is 23 pounds +/- a bit depending on cages/wheels/tires du jour. Currently running last year's Mavic Crossmax SL and Michelin XCR Dry UST rubber. I will change out the stem/bar/grips (currently ordered) and then I'm done unless I can find an affordable set of 4Ti eggbeaters. I need to stop spending on the bike and get the engine into shape...
    Jouko
    since 4/10/2009
    Reputation: Harold's Avatar
    My 2003 SJ FSR Comp is right at 28lb right now. It's got the stock frame, fork, rear shock, bars/stem/seat/seatpost, and F/R der right now. The unstock equipment is as follows:
    Shimano XT Hollowtech II crankset w/outboard bearing bb
    Crank Bros Candy SL pedals
    XT cassette
    XTR shift cables
    02 Magura Julie discs 180/160
    07 Mavic CrossTrail Disc wheels
    Planet Bike downtube fender
    Spec computer
    It was just over 29lb, so the new wheels alone shaved just over a pound off the weight of the bike. It just FEELS much faster now. No pics right now...I've got salsa skewers on order.
    My Epic Comp weighed in at 27.86lbs tonight after I installed an XTR cassette
    :wq
    My Stumpjumper HT weighs about 21,2 lbs
    ejh
    ejh is offline
    my 06 s-works FSR carbon comes in at 27.5 lbs. XT cranks & cassette, 07 XTR rapid fire and r/d 07 XTR wheels with UST Pythons, S-works carbon bars, Ritchey WCS stem, Fox Talas fork Thompson seat post.
    Reputation: Wick's Avatar
    Apr 2005
    Stumpy Weights
    2006 Large S Works, 26.5 lbs-maybe slightly heavier with the Ignitors
    College Boy
    Reputation: Timeless's Avatar
    Quote Originally Posted by mikebowyer
    come on
    I think they go fine in the same sentence because it does speed up describing everything.
    For example I have a base model 07 rockhopper that is complete stock except for the pedals which I changed over to M520's.
    It saves me a lot of time writing stuff out because I only really changed one thing on it.
    J\V
    J\V is offline
    Reputation: J\V's Avatar
    My '07 Epic Marathon weighed in at 25.9 lbs. with Crossmax SLRs, PDM-959 pedals, Roll-X Pros and SlimeLite tubes. [No, I'm not yet convinced about going tubeless...]
    '12 Santa Cruz Tallboy C w/2015 Crossmax SLs
    '10 S-Works Tarmac SL3 w/Zipp 404s
    Dec 2004
    I just got an '07 Epic Marathon as well. size large. stock except X.0 grip shifts, Candy Ti pedals and Maxxis CrossMark ExCeption tires. weighs in at about 25.8 according to the electric scale in the LBS.
    Reputation: biko30's Avatar
    my 06 epic comp weighs a hair over 26 lbs. size large
