Results 1 to 7 of 7
Thread: Why BB30?
    Why BB30?
    Just looking over the Camber and the SJ for my girlfriend for next year and I notice they have BB30. Does anyone know why Spesh would do this? I recently had to replace the BB30 bearings on my Cannondale road bike and it's a huge pain in the a$$.
    What was wrong with threads? Now you need a hammer and a special press and loctite and you have to wait 24 hours for the loctite to harden? You run the risk of ovalizing your bb shell every time you change bearings and if so your frame's now garbage? One more thing I can't fix myself....
    I like turtles
    Reputation: TiGeo's Avatar
    I believe it's PF30...not BB30 on these bikes. It uses sleeves to hold the bearings..no need for loctite. Mine has been fine..no need to worry about it IMHO.
    Sent from my SCH-I545 using Tapatalk
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Reputation: campergf23's Avatar
    Aug 2013
    My SJ uses a PF30, it's a 2013 comp hardatail
    Quote Originally Posted by SJDude View Post
    Q: Does anyone know why Spesh (and the cycling industry) would do this?
    A: One more thing I can't fix myself.
    I think you already figured it out
    old fart
    Designed to allow more flexibility for the manufacturers in their build of frames - BB30 is very critical of tolerances whereas PF30, due to its plastic cups allows more latitude. The benefits of using of an alloy 30mm spindle rather than the steel 24mm Shimano (or GPX) spindle is a mater of eternal debate.
    Reputation: WR304's Avatar
    Why BB30?
    Quote Originally Posted by skiwi View Post
    One benefit of the alloy 30mm spindle is that when your bottom bracket is full of water you'll get clear water, rather than brackish brown water dripping out from inside. The steel spindle of my Shimano Deore XT chainset is gently rusting away.
    Fat-tired Roadie
    Nov 2007
    The best justification I've read is that putting threads in a plastic frame sucks, adds weight, and costs money. The new 30 mm spindle standards don't require the frame to be threaded, so better compatibility with the plastics a lot of high-end bikes are made of now.
  1. BB30 crank on non-BB30 bike
    By reformed roadie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2013, 02:35 PM
  2. BB for BB30
    By FredrikH in forum Weight Weenies
    Last Post: 03-13-2012, 09:01 AM
  3. XX BB30 Cranks non-BB30 compatible?
    By Ginga in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-28-2011, 09:41 PM
  4. Replies: 6
    Last Post: 03-15-2011, 01:58 PM
  5. BB30? Help!
    By BoostN7 in forum Cannondale
    Last Post: 02-21-2011, 11:47 AM
