Page 88 of 92 FirstFirst ... 38 78 84 85 86 87 88 89 90 91 92 LastLast
Results 2,176 to 2,200 of 2290
  1. #2176
    Oct 2012
    South east Wyoming. Its melting fast however.
  2. #2177
    Reputation: chrishei1's Avatar
    2013 epic s-works
    Just put on some new S-Works renegade and S-Works Captain tires and ESI grips
  3. #2178
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    My 2012 Stump Jumper HT 29er.
    I installed some ENVE Carbon sweep bars 740 mm.
    ESI Chunky Grips
    Light Bicycles Hook Bead Less Carbon Wheel set with Chris King ISO 28 hole hubs with DT SWISS Comp spokes white with Red alloy nipples.
    Specialized Captain 2.20 Control front.
    Specialized Renegade 1.95 Control Rear.
    Running tubeless with Stan's Tape valves and sealant.
    <a href="http://s668.photobucket.com/user/PauLCa916/media/E1BC8E85-1283-4101-878A-BD7D9BD7472B_zpspyiqmkec.jpg.html" target="_blank"><img src="http://i668.photobucket.com/albums/vv50/PauLCa916/E1BC8E85-1283-4101-878A-BD7D9BD7472B_zpspyiqmkec.jpg" border="0" alt=" photo E1BC8E85-1283-4101-878A-BD7D9BD7472B_zpspyiqmkec.jpg"/></a>
    <br>
    <a href="http://s668.photobucket.com/user/PauLCa916/media/EFD19C67-EA0F-42BE-94E7-EDD64F7F63FD_zpsofulvbqm.jpg.html" target="_blank"><img src="http://i668.photobucket.com/albums/vv50/PauLCa916/EFD19C67-EA0F-42BE-94E7-EDD64F7F63FD_zpsofulvbqm.jpg" border="0" alt=" photo EFD19C67-EA0F-42BE-94E7-EDD64F7F63FD_zpsofulvbqm.jpg"/></a>
    <br>
    <a href="http://s668.photobucket.com/user/PauLCa916/media/0229D45F-B0C3-48E1-9CCB-B13C161C0E1B_zpsqwhafveb.jpg.html" target="_blank"><img src="http://i668.photobucket.com/albums/vv50/PauLCa916/0229D45F-B0C3-48E1-9CCB-B13C161C0E1B_zpsqwhafveb.jpg" border="0" alt=" photo 0229D45F-B0C3-48E1-9CCB-B13C161C0E1B_zpsqwhafveb.jpg"/></a>
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Manitou TI Bulge Fork / 1 x 10 P.O.S.​
  4. #2179
    Hey PauLCa916,
    I was thinking of ordering those same rims from light bike. Are they any good?
    Also what size hubs did you get and from where?
    -k
  5. #2180
    Jun 2013
    Quote Originally Posted by firebook23 View Post
    Hey PauLCa916,
    -k
    I haven't had a chance to ride them on any serious trails yet rode them around the neighbor hood after airing them up felt pretty firm but they had 35 psi in front and rear.
    I will get back and report after I drop the air pressure to normal 25 psi rear and 20 psi front and hit some single track.
    As far as how good they are according to the (Cheap) Chinese Carbon Rims Thread here on MTBR they seem to be very well built.
    (Cheap) Chinese Carbon Rims?
    As far as Hub's I'm running Chris King ISO 28 hole front 9 mm T.A and rear 10 x 135 QR.
    Bought them from a a guy online new.
    SRAM XX1
  6. #2181
    May 2014
    I painted the writings on the tyres
  7. #2182
    Re: What's The Latest Thing You've Done To Your Specialized Bike?
    Replaced seatpost with Ritchey Superlogic 1bolt and handlebar with a Syntace Vector Carbon and ESI grips.
    Enjoy the ride!
  8. #2183
    Reputation: mtnbkr80015's Avatar
    New seat, grips and stem
    Already switched the tires (2.3 Ground Control front, 2.0 The Captain rear, both tubeless and Control casing), EC90 seatpost, EC70 720 mm flat bar and added 2 carbon rib cages and S.W.A.T. mini tool. The new stem is an 80mm x 6 degree rise Kalloy Uno "6", the grips are Vans ODI Lock on, the seat is a 155mm Specialized Romin Expert Evo. Oh yeah, switched the brake pads to 7.1 performance compound. Now it is set up right for Colorado singletrack!
  9. #2184
    Reputation: Trail_Blazer's Avatar
    May 2012
    Loving the Swat minitool bottle cage.
  10. #2185
    May 2014
    Green stickers on rims
  11. #2186
    Reputation: Apache Sonora's Avatar
    Jun 2014
    Got this slx brakes to replace some POS avid elixir 3 on my camber.
  12. #2187
    DFMBA.org
    Reputation: MTBeing's Avatar
    Added an Easton EC70 seatpost to get rid of the creaking/crackling from the oem unit. I did like the quality of the Spec seatpost; too bad it made too much noise. The Easton is sweet and silent. The s/p collar is Fourier's and it rocks.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
  13. #2188
    Jun 2013
    Quote Originally Posted by PauLCa916 View Post
    After riding these LB carbon rims a bit I'm very pleased with the purchase.
    Bike tracks better especially in the corners.
    Even climbing they seem better.
    As far as durability so far after hitting some rock gardens pretty sloppy I must say.
    I just took them to my LBS and had him check them out and they are still true and tension is fine.
    Just recently changed out the stock Specialized 105 mm stock stem to a Thomson 70 mm 0 rise stem.
    Couldn't believe what a difference it made still getting use to it.
    <a href="http://s668.photobucket.com/user/PauLCa916/media/2014-07/ABE54F51-1162-4056-8650-A0A0955A233A_zpsrkqjboxw.jpg.html" target="_blank"><img src="http://i668.photobucket.com/albums/vv50/PauLCa916/2014-07/ABE54F51-1162-4056-8650-A0A0955A233A_zpsrkqjboxw.jpg" border="0" alt=" photo ABE54F51-1162-4056-8650-A0A0955A233A_zpsrkqjboxw.jpg"/></a>
    SRAM XX1
  14. #2189
    Another update on my Stumpy. Finally finished the conversion to Evo spec and it now has 150mm of travel front and rear. The Pike is such a huge upgrade over stock. Turned my Stumpy into a monster truck, just goes through everything. Absolutely love this bike.
  15. #2190
    May 2012
    Just set a new pair of tires with stans; 2blis Sworks Ground Control 29 2.3 front and 1.9 back. Light, supple and durable.
  16. #2191
    Reputation: morando6784's Avatar
    Jun 2012
    Not as fancy as most of your guys bikes but started building up this old hardrock frame. Started bare aluminum.
  17. #2192
    What's The Latest Thing You've Done To Your Specialized Bike?-20140811_144226.jpgWhat's The Latest Thing You've Done To Your Specialized Bike?-20140811_144312.jpg
    2015 YT Capra Pro Race LE
    2013 Specialized Stumpjumper FSR Comp 29er
  18. #2193
    Jun 2012
    Got my tires on
  19. #2194
    Got me some new pedals
  20. #2195
    Well, another update, probably the last on this bike (at least until those new WTB carbon rims are available!). Swapped the drivetrain to full XT, a 32T Narrow Wide from Raceface, KMC X10 gold chain, E13 Turbocharger, and the 42T and Rad Cage from One Up Components. Mid swap I spent a couple hours cleaning the bike and touching up the chips in the paint, so it gets to sit on some carpet until the next ride. Love this bike!
  21. #2196
    Quote Originally Posted by SDKmann View Post
    say, that's a nice bike! what do you use for touchups?
  22. #2197
    I took a rattle can of matte black Krylon Fusion and sprayed some on a paper plate before applying some with a q-tip. Turned out really well, you have to be looking really closely to identify where the chips and scrapes were.
  23. #2198
    Reputation: RS VR6's Avatar
    Finally got my XX1 crank.
    30T
    170mm
    168Q
  24. #2199
    May 2012
    New 2x10 XT Drive Train
    22/33 Wickwerks ChainRings
    Hope Bash Guard 34T
    I may need to remove 1-2 links more tho.
  25. #2200
    That setup looks great Trail Blazer, especially love that Hope bash.
