Page 32 of 47 FirstFirst ... 2228293031323334353642 ... LastLast
Results 1,551 to 1,600 of 2331
  1. #1551
    Reputation: dhmatt's Avatar
    my 2011's
    2011 Enduro comp mostly stock the only upgrades are Sunline am stem w/Sunline V1 bars, Maxxis Highroller rear and Dark cycles bash guard for a little bling.
    2011 SX Trail with a custom build
    totem solo air
    raceface atlas bars and crankset
    thomson stem and seat post
    x9
    outlaws
    Attached Thumbnails Attached Thumbnails What's The Latest Thing You've Done To Your Specialized Bike?-333971_10150307971551933_566276932_8248209_1748958467_o.jpg
  2. #1552
    The new ergo grips from specialized and a shorter stem.
    Sent from my SCH-I510 using Tapatalk
  3. #1553
    Oct 2011
    The latest thing lol
  4. #1554
    just got a forte carbon seatpost and racing ralphs for my '10 epic carbon.
  5. #1555
    Sold my 08 Rockhopper.
    Now I have a 2012 SJ EVO comp that should be here before December.....
  6. #1556
    Mar 2011
    New stuff on Epic
    I put newe brake pads on back and front. New XTR pedals! Looking at Easton Haven Carbon or Roval Carbon 29's. Any help with that decision? Anyone know about the adapter to use on an 11 epic expert carbon and putting 135mm hubs on back from 142+?
  7. #1557
    New stuff on 2010 Enduro
    Hi.
    Just added a Command Post seat post and the carbon Rock Guard. Pretty cool...
    Also added the roof bar and bike carrier to the auto "can"...
    it's not a Specialized, but it will do fine as a "speshmobile"... lol
    Attached Thumbnails Attached Thumbnails What's The Latest Thing You've Done To Your Specialized Bike?-dsc01085.jpg
  8. #1558
    I put a '11 Reba RLT fork on my '08 RH Disc.
  9. #1559
    Lets see,
    Went on a plannned ride with two cousins 3.5 hrs away, and 3 miles into a 10 mile loop, I busted the ***** out of my chain, and messed up the cassette pretty good. So I upgraded the following;
    I went 2x10 w/
    Sram 10 speed cassette 12-36
    X9 Long Cage RD
    X9 Shifter
    New KMC X10SL Gold Chain
    Other things I have done are:
    Thompson Elite Stem (after finally finding the right length and rise)
    Went 2bliss with some Renegade Controls 1.95 ( I love how fast they are, but as you might be able to see in the picture, they are caked with mud. NOT A TIRE FOR MUD OR WET LEAVES OVER ANYTHING!! : ) I have some 2.2 Purgatory's coming for the wet fall season.
    I debadged the C29ssmax wheels, and partially debadged the Manitou Tower Fork.
    IMG_0391-1 by jonshonda187, on Flickr
  10. #1560
    Oct 2011
    I toke it out of my bed X)
  11. #1561
    Is not amused
    Reputation: Hutch3637's Avatar
    Pedals and Shoes
    Attached Thumbnails Attached Thumbnails What's The Latest Thing You've Done To Your Specialized Bike?-imag0348.jpg
    Yip yip yip nope nope nope
  12. #1562
    Oct 2011
    just slapped on some maxxis minion dh supertacky tires
  13. #1563
    Nov 2008
    New stem & handlebar combo...
    I only use the brake, so I can accelerate all over again...
    ..:: www.THELOBBY09.com ::..
  14. #1564
    Bike Breaker.
    Been spoiling my evo.
    Air sleeve service on the evo, new seals, slick honey and float fluid.
    Bearing re-grease on the clevis.
    Cassette chain and chainset de-grease.
    New tyres ordered as can't find Butcher control's in the UK so a pair of Hans Dampf trail star ordered.
    Rovals serviced and new blue tubeless strip applied.
    Thomson 70mm stem back on and easton 685 bar.
    Haven stem and Answer bar relegated to the on-one 456.
    ODI red troy lee grips put on.
    all stripped and cleaned.
    Hopefully tyres here tomorrow and am allowed back on the bike after 4 weeks off because of a broken finger.
  15. #1565
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    Just a little service. Nothing wrong with taking it apart, cleaning it till it's perfect, greasing er back up, and be on your merry way. Just the OCD side of me.
    Attached Thumbnails Attached Thumbnails What's The Latest Thing You've Done To Your Specialized Bike?-299911_10150344877667840_816457839_8291920_381901012_n.jpg
  16. #1566
    GoCyco
    mystery noise solved
    I just added a zip tie around my RD cable and chainstay on my Epic Expert 29er. I was hearing this strange noise on some rides and it turned to be the tire knobbies hitting the cable on occasion.
  17. #1567
    Flat six
    I picked up an S-Works Ground Control 26x2.3 for my 2011 Stumpy Comp. I originally intended it put it on the front and move the stock S-Works Purgatory 2.2 to the back, replacing the waaaaay too small The Captain Control 2.0. The Captain had too little braking and cornering traction, and never felt very solid on jumps and rough descents.
    After mounting, I noticed the Ground Control seemed pretty narrow for a 2.3. After remounting both other tires and comparing all three, I found that the Ground Controls width fell in between the 2.2 Purg and the 2.0 Captain. The Ground Control was taller than The Captain, and on par with the Purgatory.
    This worked out pretty well. I was happy with the purgatory, so I left it mounted on the front and put the GC on the back. It's made a huge difference. Braking and cornering are much improved, and the bike feels a lot more solid in the rear. Before the rear suspension felt somewhat harsh over roots and jumps, but now feels much better. Rolling resistance feels about the same, which is impressive considering it's wider, taller, and much more grippy.
    Aside from the questionable sizing, this is a great tire. I'd highly recommend it for anyone looking to replace a The Captain, especially if you're wanting to beef up the rear on your stumpy. Why Spesh would put such a tiny rear tire on a 140mm travel bike is beyond me, but this was definitely a good solution.
  18. #1568
    Fixed a horrid noise emanating from the rear derailleur area of my Epic Carbon Evo R 29er. Thought it was the derailleur, but wasn't 100% sure. Rebuilt it, no change in noise. Rebuilt the shifter(I'm now an expert on the Sram X9 shifter assembly), no change. Fiddled with it tonight and figured out the cassette lock ring was loose, causing the cogs to do some weird things. I have the Roval wheels, so I pulled the cassette apart, greased the assembly, put it back on, and then tightened the cassette down as tight as I dared.
    Put it back together, and guess what? No more noise! I was about ready to resort to buying a $200 derailleur... Woot Woot!
  19. #1569
    Oct 2011
    Dug it out of the basement....
    A few weeks back I dug my Rockhopper Comp (1993 if I remember correctly). Half the gears are not working. Not sure if I am going to put money into it.....or buy something new in the Spring.
    Maybe I will do both
  20. #1570
    Jun 2005
    Sold 07 stumpy Pro Carbon for 2011 Tallboy. Perfect upgrade.
  21. #1571
    Has anyone done a ceramic bearing bottom bracket upgrade with the SRAM PF crankset on the StumpJumper? How do you like it?
  22. #1572
    Oct 2011
    Contienental Race King/Mountain King tires!
  23. #1573
    It's all about the FSR!
    Reputation: Heavy Fluid's Avatar
    Mar 2011
    OURY lock on grips.
    Red Salsa seatpost clamp
    Shimano SPD 520's
    Kenda Nevegal up front
    Kenda Smallblock 8 rear
    Sun Ringle Charger wheels w/ Sun Ringle Dirty Flea hubs
  24. #1574
    Team Fainting Goats
    Carve Expert
    Added a Specialized wagonwheel hesdset covrt, and Shimano XT pedals, PD-M780. Love them.
  25. #1575
    Got it dirty
    IMAG0010 by Alasdairs, on Flickr
  26. #1576
    I did these all at one time on my GF's '08 RH Disc. Pix were taken with an iPhone so sorry about the poor quality.
    '11 Rockshox Reba RLT Fork
    WTB VelociRaptor Tires
    Sunline V1 Peddles
    ODI Rogue Grips
    The total package
  27. #1577
    Mar 2011
    ^ wife had one of those to start out on. She loved it. Same color and all. Looks nice.
  28. #1578
    Quote Originally Posted by Heavy Fluid View Post
    Thanks, she loves it & I don't think she'll ever part with it. As long as the frame holds up, I don't mind upgrading components as they wear.
  29. #1579
    Reputation: Sugar_Brad's Avatar
    Renthal bars
    QBP finally got some Renthal bars.
    " width="549">
  30. #1580
    Reputation: chantheman84's Avatar
    I just change my pedals again! Time atac Aliums , bent the first set of Aliums on the first ride on our trails.
    Anyone have any suggestions on time pedals that won't bend , if I go to the more expensive one like the xs or roc are they less likely to bend LMK? I bent every single pedal I put on any bike , and if the pedals do hold up , the crank arms or brackets bend, I'm only 156lbs and need advice. FSR XC 09.
  31. #1581
    Mar 2011
    Quote Originally Posted by Call_me_Tom View Post
    How short is that stem on the RH?
  32. #1582
    I dont know, it's the factory stem. I was looking at replacing it one of these days, but I want to upgrade the drivetrain to X9 or XT components first. I'll replace it when I replace the seat post & handle bars.
  33. #1583
    Reputation: crclark27's Avatar
    Added some trail rash to the right side. Had to have shed a few ounces right?
  34. #1584
    I put a 36 Fox Van 160 RC2 2012 and a DHX RC4 2012 in an Enduro Expert 2010
  35. #1585
    Reputation: Prat859's Avatar
    Oct 2011
    I removed the reflectors and dork disc 2 hours after purchase
  36. #1586
    Quote Originally Posted by chantheman84 View Post
    That just doesn't seem right. I've bent seat posts and saddles but never pedals or cranks and even those were on a hardtail.
    I've done a bit of downhill on my FSR XC so what on earth are you doing to bend them?
  37. #1587
    Reputation: moofish's Avatar
    Spot the difference!
    No its not that the chicken is gone. Now my Ground Control Aim with a Mc Pherson strut now has a FSR rear end. I am lucky to be an industrial electrician and a welder owed me a favor so I got the tabs welded onto my frame and I installed the back end from a damaged frame I got on ebay for 99c Why bother? why not?
    Attached Thumbnails Attached Thumbnails What's The Latest Thing You've Done To Your Specialized Bike?-imag0571.jpg
  38. #1588
    interesting. How does it work? The rear shock angle does not look optimal.
  39. #1589
    When I sit on it the shock sags enough to improve that angle. I have ridden it on the road but Im yet to test it going downhill. I put the chicken back on so it looks much better now.
  40. #1590
    Reputation: mtnbkr80015's Avatar
    Put new grips and a Command Post Blacklight on my new S-Works
  41. #1591
    Put new well-go platform pedals and specialized ergo grips on my Hardrock. Waiting on supplies to go tubeless.
  42. #1592
    just put a pair of slicks on my '08 hardrock...because my 2012 GF cobia is on order. Rides smooth for an old mountain bike. A lot easier on the legs.
  43. #1593
    Feb 2007
    Ss
    I've been converting an old rockhopper (1986 vintage) to SS. Might also make it a 1x9.
    Steve.
  44. #1594
    New additions to my 06 Stumpy:
    - WTB Rocket V
    - Thomson Elite Seatpost
    - Carbon water cage (this thing is amazing btw)
    Wish list/ To do list:
    - Thomson Set back seatpost (PM if anyone has one to sell, silver color only)
    - ODI lock on grip
    - Monkeybar
    - new pedal (feel free to PM if anyone has a good pair to sell, prefer white color)
  45. #1595
    swapped the stock casette to a SRAM PG990 redwin on my '10 epic carbon.
    i know it's all in my head but my wheels seemed to just keep rolling
  46. #1596
    Dec 2010
    Put it in my basement storage room to make room in the garage
  47. #1597
    Just ordered Avid BB7's!
  48. #1598
    Quote Originally Posted by Jacknife417 View Post
    Bravo, make sure you get some Speed dial levers to go with it. It'll make a world of difference in stopping power!
  49. #1599
    Levers are next on the list. Can't wait for the stopping ease of this setup.
  50. #1600
    Picked up some Oury lock-ons.
